Old 10-08-2018, 05:06 AM
dougie dougie is offline
dougie is on a distinguished road
Default H2 transmission
My 2003 H2 started auto trans problems. I had to manually put shifter into 1st gear then 2nd--it would not go into higher gears. I installed a new shifter cable and the auto will still not work but I can manually get it into 3rd gear but no higher. Has anyone any suggestions as to the problem or what I can do to fix the problem?
Old 11-20-2018, 04:41 AM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Default Re: H2 transmission
You mean you can manually shift but when you put it in D it won't shift?
2005 H2 SUT
