Old 01-29-2004, 01:10 PM
CRUZMISL CRUZMISL is offline
CRUZMISL is off the scale
If I take a right turn fairly quickly, say making a right turn on to another street, I hear a knock that seems to come from the center of the truck. Any ideas what could cause this or what it could be?
Thanks,
Joe
Thanks,
Joe
Old 01-29-2004, 01:16 PM
Joe,
Check you center console glove compartment.
It's probably your plastic dildo rolling around.
" S & B Member Since 2003 "
Old 01-29-2004, 02:57 PM
frank6150's Avatar
LMAO!!!!
S&B Member since '03
Old 01-29-2004, 03:35 PM
Everyone is a comedian
Old 01-29-2004, 07:11 PM
Klaus's Avatar
Klaus Klaus is offline
Actually, you have the Dirt Track Edition of the H2. Your truck was made to only turn left.
I'll see if I can find any TSBs on it tonight.
Klaus
Rare 2003 H2 with UM8 Integrated Navigation Radio
Skull & Bones Member since 2003
Old 01-29-2004, 07:33 PM
Thanks Klaus!
Old 01-29-2004, 09:57 PM
Klaus's Avatar
<HTML>
<HEAD><TITLE>Service Information</TITLE></HEAD>
<BODY BGCOLOR="#FFFFFF">
<form name='topNavForm' action='/servlets/CellHandler'>
<table width='100%' align='CENTER'>
<tr>
<td width='25%' slign='LEFT'>
<input type='BUTTON' name='back' value='<- Back' onclick='java_script: history.back[);'><input type='BUTTON' name='forward' value='Forward ->' onclick='javascript: history.forward();'>
</td>
<td width='50%' align='CENTER'>
Document ID# 699820
2003 HUMMER H2
</td>
<td width='25%' align='RIGHT'>
<input type='BUTTON' name='print' value='Print' onclick='java_script: window.print[);'>
</td>
</tr>
</table>
<HR>
</FORM>
<H1>Clunk Noise When Accelerating During Turns</H1>
<TABLE WIDTH="100%" BORDER=1>
<TR>
<TH ALIGN="center" VALIGN="bottom" ROWSPAN=1>
Step</P>
</TH><TH ALIGN="center" VALIGN="bottom" ROWSPAN=1>
Action</P>
Yes</P>
No</P>
</TH></TR>
<TR>
<TD ALIGN="center" VALIGN="middle" ROWSPAN=1><A NAME="S01">
1</P>
</A></TD><TD ALIGN="left" VALIGN="top" ROWSPAN=1>
Check for worn or damaged outer
CV joints and/or seals.</P>
Are the outer CV joints/seals worn?</P>
</TD><TD ALIGN="center" VALIGN="bottom" ROWSPAN=1>
Go to
Step 2
</P>
System OK</P>
</TD></TR>
<TR>
<TD ALIGN="center" VALIGN="middle" ROWSPAN=1><A NAME="S02">
2</P>
Replace the outer CV joints/seals.
Refer to
Wheel Drive Shaft Outer Joint and Seal Replacement
.</P>
Is the repair complete?</P>
System OK</P>
--</P>
</TD></TR>
</TABLE>
<form name='bottomNavForm'>
<hr>
<tr>
</td>
Document ID# 699820
2003 HUMMER H2
</td>
</td>
</tr>
</table>
</form>
</BODY></HTML>
Klaus's Avatar
Sorry, the above post is all I could find.
Klaus
Old 01-29-2004, 10:31 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Every once in a while I heard a clunking that was driving me NUTZ I finally figured out it was my passenger side seat belt hitting the door panel!
Old 01-29-2004, 11:05 PM
alecs wife alecs wife is offline
alecs wife is off the scale
I have the same thing. It is comming from the right front upper control arm. When turning the bushing is piviting and making a klunking noise. My dealer ended up replacing the idler arm and one of the hub seals. It helped but I think its a temp fix.
R2
Front Locker, Stealth winch, 37" Super Swampers SSR,low center of gravity = Ultimate H2
CONFIDENTIALITY NOTICE: This post and any pictures posted with it are the property of Adam in CO and/or his affiliates. The contents of this post are confidential and may contain information that is privileged and/or exempt from disclosure under all
Old 01-30-2004, 02:55 AM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
Have you counted your children lately?
You may have one stuck in the glove box wanting to get out?
Ric-H2
www.meatspin.com
