Old 03-23-2006, 01:43 PM
Ernie Italy is off the scale
Anyone have the alignement data ?
Camber - Toe ecc ecc
Old 03-23-2006, 05:49 PM
alignment - Toe - Caster - Camber
Pleeeeeaaaseeeeee
...and many thanks!
Old 03-24-2006, 03:02 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Suspension Options
Caster
Cross Caster (L - R)
Camber
Cross Camber (L-R)
Total Toe
Steering Wheel Angle
Left
Right
Important
Caster is relative to frame. The caster values must be compensated for the measured frame angle. Frame angle is positive when higher in the rear and negative when lower in the rear. Refer to Front Caster and Camber Adjustment .
With RPO ZM6
4.25 ± 1.00
4.75 ± 1.00
-0.5 ± 0.50
+0.25 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
-1.0 ± 3.5
Without RPO ZM6
4.25 ± 1.00
4.75 ± 1.00
-0.5 ± 0.50
+0.25 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
-1.0 ± 3.5
1998 Chev Z71
2007 Chev Trailblazer SS
Old 04-18-2006, 06:52 PM
ree's Avatar
ree ree is offline
So whose data is righter? Look at the link phil provided for "With RPO ZM6"
Caster (left) : 4.00 ± 1.00
Cross Caster (L-R) : -0.75 ± 0.50
Whereas HUMTECH's numbers for those are:
Caster (left): 4.75 ± 1.00
Cross Caster (L-R): -0.5 ± 0.50
HUMTECH's numbers are the one's I've gotten from my dealer.
Phil, do you have a typo? Or are there differences in model years?
I don't have the ZM6 option, but someone who does might care.
'03 pewter base H2
Old 04-19-2006, 05:09 AM
Data for 04 from Hummer Service
4.25° ± 1.00°
4.75° ± 1.00°
-0.50° ± 0.75°
+0.25° ± 0.60°
0.00° ± 0.60°
+0.10° ± 0.20°
-1.00° ± 3.50°
