Old 03-01-2006, 02:18 AM
UNOMYFLO UNOMYFLO is offline
UNOMYFLO is off the scale
I posted this in the H1 forum by accident...
I have some oil weeping from the timing cover bolt...the one that you can see right above the crank pully bad thing is to either remove it to put some silicone on it and re-install it to stop the SMALL leak or even to tighten it is impossible without removing the pully from the crank as just half of the head is exposed......
Have you seen this on any other H3's?
should I be concerned other than hating any oil leaks juts a weep no drip on the shield underneath...
what would be you fix and is there one w/o removing the lower crank pully?
do you have the weep?
does nayone else?
look at the lower pully its the small bolt recessed into the tining cover right above behind the bottom crank pully.
also F5 any ideas or new info on the rattle thread??
can you ask around? I know you have contacts we dont seems a few have i someone must know about it or have a fix?
thnx
UNO
