Old 03-27-2005, 02:48 PM
RI Hummer RI Hummer is offline
RI Hummer is off the scale
I need to replace the wimpy horn on the Hummer. Any suggestions for the upgrade? I'd like to just use one that works off the existing horn and junk the wimpy one.
Old 03-27-2005, 03:02 PM
Can this be wired to the existing horn?
Air horn kit
Old 03-27-2005, 03:24 PM
tower's Avatar
tower tower is offline
RI,
If your asking if this can be set up to be operated by your current horn switch, the answer is yes. But it is an elaborate set up. For around 10% of that price, you can get airhorns from Hella, Fiamm, etc which have small high speed compressors, multiple horns and get more attention than the ones you are contemplating. I had 5 differently sized (different frequency) small horns and 2 compressors in my Tahoe. I routed the tubing so that both compressors fed all 5 horns. Lets just say no one ignored my horn.
http://www.autobarn.net/noname6.html
http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&productId=357181&R=357 181
http://www.duettomotors.com/miata/horns.htm
t~
Old 03-27-2005, 07:28 PM
D.Wiggs D.Wiggs is offline
D.Wiggs is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by RI Hummer:
Air horn kit </div></BLOCKQUOTE>
RI,
I hav ethat exact horn in my rig and it took the dealer only about 30 minutes to install. It is very simple and it was specifically designed to go in the H2 so it fits perfectly. It comes with a switch so that it can be wired such that you can use your factory horn until the switch is flipped and then you will get the airhorn. The airhorn sounds great and the best part is, the self-contained unit has an air compressor that you can use to air up your front tires etc. as easily as the rear compressor can do the rears without some super-long hose. I would definitely recommend it!
Just my two cents.
D.Wiggs
Old 03-30-2005, 02:19 AM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Does anyone have this:
H2 HELLA DUAL AIR HORNS
Old 03-30-2005, 02:23 AM
LasVegas LasVegas is offline
LasVegas is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Does anyone have this: </div></BLOCKQUOTE>Yeah....I can fart louder than the horn. Gonna replace it with a real one.
Jonahs
Old 03-30-2005, 03:06 AM
tower's Avatar
Damn, Jonas, those must be some wicked-powerful farts. When I had the 5 air horns and 2 small compressors in my Tahoe, it sounded like a freight train>
Old 03-30-2005, 03:15 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by tower:
Damn, Jonas, those must be some wicked-powerful farts. When I had the 5 air horns and 2 small compressors in my Tahoe, it sounded like a freight train> </div></BLOCKQUOTE>Well tower~ if I had 5 *******s (some think I do) I guess you'd be right. Check the pics under your express sunroof help thread. Whatcha think??
Jonahs
Old 03-30-2005, 04:09 AM
tower's Avatar
ROTFLMAO Very good reply!
Old 03-30-2005, 06:45 PM
ChuckE ChuckE is offline
ChuckE is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by LasVegas:
Yeah....I can fart louder than the horn. Gonna replace it with a real one. </div></BLOCKQUOTE>
How do you replace a fart?
And, is that called an "Ass Blaster"?
and does it look like this?:
\"I asked my wife for a hummer, she gave me this H2.\"
03 White H2 Adventure, sunroof, Garmin GPS, Air Horns, Diablo Sport Programmer
Old 04-10-2005, 01:03 PM
TheWB TheWB is offline
TheWB is off the scale
142db complete train horn system
ExtremeCarVideo.com
Old 04-10-2005, 06:02 PM
WB, that's perfect. Just what the doctor ordered. I wonder if I could sneak that in the truck without the wife finding out.
Old 04-14-2005, 08:05 PM
Even if you could sneak that past her, I think the first time you hit the horn button, she'll notice the difference! (As well as all your neighbors)
ExtremeCarVideo.com
Old 04-14-2005, 08:47 PM
Dan Dan is offline
Neighbors? Did someone say neighbors??
I'll be picking one of those babys up!
Old 04-14-2005, 09:32 PM
DLEPEZ DLEPEZ is offline
DLEPEZ is off the scale
Does any know how installation is on that thing (if it is difficult/easy, etc). I'm thinking about picking one of those up but not sure if I can install it myself
Pewter \'03; Eclipse CD/DVD/Nav; 2 12\" JL 12W7\'s; 3 ARC Audio Amps; Diamond audio mids/tweeds; 15 flip down monitor; BFGoodrich Mud Terrains; 18\" Lexani V.P. Offroads; Volant intake; SMA Exhaust
Old 04-15-2005, 01:44 AM
I'll be picking one of those babys up! </div></BLOCKQUOTE>Good one, Dan! You could hit it while you're "speeding" by their house.
I guess you'd have to mount the tank in the rear of the truck, inside. And where to put the horns? Is that thing legal? I know some train horns aren't.
Can you tell I'm really thinking about it?
Old 04-15-2005, 11:40 AM
Ken,
You can mount the compressor in the engine bay, mount the tank in between the frame rails in the rear and also plumb it for regular air fittings to air the tires faster than the stock compressor. I have a 5 gallon air tank that I am going to mount one day along with a compressor and will buy just the horns to add to the system if I ever get the air system done.
This looks like a good system: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14932&item=5767654 800&rd=1
Old 04-15-2005, 06:50 PM
Paragon, that one's alot more money. But it does have the separate compressor which would make mounting it easier. The one above his mounted together. Well, maybe they come apart.
I think it was nixed last night when I was laughing while listening to it. The copilot heard it and said something about lawsuits, wrecks.... I don't know...
Old 04-15-2005, 11:04 PM
I think it was nixed last night when I was laughing while listening to it. The copilot heard it and said something about lawsuits, wrecks.... I don't know... </div></BLOCKQUOTE>I can't believe that! It would be a lot more vocal on their "dates."
