Old 06-27-2005, 01:30 AM
VTSTOMPER is off the scale
So I was making my way to a birthday party and moving down the highway pretty good when I see in my passenger mirror a small black thing whipping around in the wind. I stop at the next exit to find that the rubber "seal" (if you can call it one, it is more of a spacer or anti rubbing device.) was peeling off the rear of the truck. The rubber piece is attached below the plastic that the rear running lamp is bolted to. I tossed some rubber safe adhesive on it, and I am good to go, but I almost lost it on the road.
I just wanted to send out something about it so you might want to check yours.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
