12-20-2003, 08:03 AM
I have a company called Xtremelight right now we are specializing in LED Flashlights. I'm interested in getting an opion from other Hummer owners. I know Hummer owners want the best and these will be "the best" The Housing is Aluminium and the Ballast is internal they will be 4,300 K which is a White Light color. The Retail would be about $ 500 each I will be selling them for about $ 300 each online. Were goung to have to order 100 pieces or 50 pairs. I do have samples on the way and will have them on my H2 for testing by January 1 2004. Let me know if this would of interest to anybody.
2004 H2 Xtremelight 6000K HID Xenon Headlights, Xtremelight 4300K HID Offroad Lights, 6 in Fabtech Lift, 38 in Nitto Mud Grappler Tires, 18 in Ice Metal Wheels.
12-20-2003, 03:45 PM
I'll test them on my H1, take pics off road and post them everywhere (I get to keep them right?)
12-20-2003, 04:35 PM
Can you give us dimensions & capacities. What are the lenses made out of. Are there optional lenses available(clear protective, spread beam, colored)?
I was leaning towards some LightForce HID Blitz lights, but they're too deep to mount on the front of the H2.
http://www.lightforceusa.com/240_hid.html
12-20-2003, 07:10 PM
Drtyfn, How much does lightforce want for there's?
csx164
12-21-2003, 01:31 AM
I seem to remember them being about $1000 or $1100. Not too bad since I was comparing them to Hella HIDs at the time.
12-21-2003, 02:34 AM
any specifics on the dimensions.. it looks a bit deep to mount on the brushguard. price seems right! what ideas do you have for mounting...would like a darker housing.
definitely interested.
unaslob
12-21-2003, 04:55 AM
Are those the Eagle Eyes HID's? Look identical!
Founding Member of RCRC 4wd Club Scaramento, CA www.rcrc4x4.com
Pirate4x4.com Vendor & Toyota Truck and 4Runner Talk Forum Moderator
12-21-2003, 08:36 AM
Yes they come from the same factory as the eagle eyes so they are the same. they are deep because of the internal ballast. would you all prefere the external ballast you would have to mount them inside the hood. I bought a new valance from sma that should fit the HID's inside. they will replace the 4 inch driving light's. They are the same size as the piaa 5.25 inch. I should have them on the H2 soon. Also I have some true HID Hi/Low beam replacement bulbs coming. im going to have to modify my stock headlights to fit them in as they are a H4 Bulb and we use the 9007. We will have to see.
anybody currently using the Eagle Eyes HID please give me some feed back.
12-21-2003, 03:25 PM
12-21-2003, 04:46 PM
I kinda like the all in one setup, makes it easy to swap out an older non-HID light quickly. Are you also planning rectangule HID retrofits for standard Hi/Lo headlights?
