Old 02-28-2006, 03:06 PM
saleen779 saleen779 is offline
saleen779 is off the scale
ok, dumb question. but, does anyone know how to adjust the headlights? mine are pointing too high and need to come down some. they are pretty high, to the point of that they are pointing in the rear mirrors of other h2's. i checked the owners manual but was unable to find anything on headlight adjustment. thanks.
H2 for life!
H2 for life!
Old 02-28-2006, 03:36 PM
thanks phil. guess i'll fix it when i change out my grill this week.
H2 for life!
Old 02-28-2006, 04:50 PM
well, even better then. guess i'll go fix em now! thanks again phil, you're a huge help.
H2 for life!
Old 02-28-2006, 05:27 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by saleen779:
Posted 02-28-06 10:50 AM
well, even better then. guess i'll go fix em now! thanks again phil, you're a huge help. </div></BLOCKQUOTE>I'd wait 'til dark.
Old 02-28-2006, 06:42 PM
Phil............. quit advertising
Old 02-28-2006, 06:48 PM
tomp's Avatar
tomp tomp is offline
Phil, would there be any way you could accurately measure the location of this hole, so we could drill it without removing grill?
Old 02-28-2006, 08:00 PM
tomp's Avatar
Well if I end up with headlight bezels that resemble the drilled-out OEM mini grill, who else can I blame but you Phil
Old 07-05-2006, 01:51 PM
ree's Avatar
ree ree is offline
Default Re: headlight adjustment?
Phil,
Did you ever measure the location to drill?
'03 pewter base H2
Old 07-05-2006, 02:37 PM
ree's Avatar
ree ree is offline
Originally Posted by PhilD
You're going to make me do it aren't you?
I'll do it this morning...
I'm afraid that while unhooking my grill lights while removing the brushguard and grille, I might get my hand stuck in the grille like Paragon did. I figured I wouldn't risk that if at all possible
'03 pewter base H2
Old 07-06-2006, 05:18 PM
ree's Avatar
ree ree is offline
Excellent. Thanks Phil.
'03 pewter base H2
Old 12-06-2006, 03:19 AM
Phil, you took a bit to both holes? or was one there and you drilled the other. I don't have wither and couldn't find the adjustment screw. Did they change from 03/04 to 06/07?
Since the lift was put on, the headlights need to come down for sure.
NEver mind, I found it. I'm just not sure how far down to bring them yet.
Old 09-16-2007, 12:06 AM
I finally did this mod to adjust the headlight. Now all I need to do is wait until it's dark.
Old 09-17-2007, 12:07 AM
tower's Avatar
tower tower is offline
By vertical adjustment I mean up and down, and by horizontal I mean side to side.
Is there another definition?
