Old 11-21-2003, 10:21 PM
Cincinnati h2 Cincinnati h2 is offline
Cincinnati h2 is off the scale
Has anyone tried to fit the Nitto Terra Grappler 355/65/18 tires without any lift. I was thinking about using these with 18x10 rims with a backspacing of 4.5". I can't find any place local that sells these so I can test fit them. I was going to order them on the internet but don't want to be stuck with them if they don't fit.
Old 11-22-2003, 05:34 PM
MSeeb MSeeb is offline
MSeeb is off the scale
I am running the Nitto Graplers on 18 x 10 rims with no lift, but my tires are only the 325/65R/18 and they do rub when turning sharply. I haven't found it to be a big problem, more of an annoyance. The tires are great though. I just took it on a 2500 mile road trip and the ride was smooth, and road noise was extremely low given the tire size.
Old 11-22-2003, 07:18 PM
MSeeb,
1)Do you know what the backspacing is for your wheels?
2)Are they rubbing on the inside of the tire or on the outside at the fender? I was thinking I could find a wheel with the proper backspacing to solve either problem.
3)Do they look much bigger than the stock tires? I was thinking about the 325/65/18 also but didn't know if they would look much bigger than the stock tires.
thank cincyh2
