Old 04-02-2004, 12:37 AM
Klaus's Avatar
Klaus Klaus is offline
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Service Information</TITLE>
<META http-equiv=Content-Type content="text/html; charset=windows-1252">
<META content="Microsoft FrontPage 5.0" name=GENERATOR></HEAD>
<BODY bgColor=#ffffff>
<FORM name=topNavForm action=/servlets/CellHandler>
<TABLE width="100%" align=center>
<TBODY>
<TR>
<TD width="25%" slign="LEFT"></TD>
<TD align=middle width="50%">Document ID# 1478805
2004 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE>
<HR>
</FORM>
<H1>Engine Continues to Run When You Take the Key Out of the Ignition - kw
control brake switch open B1440 run relay start part information electrical
short #PI01881 - (03/18/2004)</H1>Engine Continues to Run When You Take the Key
Out of the Ignition
.</P>
When servicing the vehicle with the VIN you entered, the following diagnosis
might be helpful if the vehicle exhibits the described symptoms. </P><A
name=ss1-1478805><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1478805&psdid=732&evc=sm#ss1-1478805">
<H5>Condition/Concern:</A></H5>
Engine continues to run when you take the key out of the ignition. You may
also find the BCM has code B1440 stored in history. Engine will shut off if you
remove the ignition 1 relay or if you dimmed the dash lights. </P><A
name=ss2-1478805><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1478805&psdid=732&evc=sm#ss2-1478805">
<H5>Recommendation/Instructions:</A></H5>
Feedback or a short in the traction control switch between ckt 230 (dash
light/back lighting/dimming) backfeeding to ckt 639 which would keep the
ignition relay turned on. Replace Brake System/Traction Control switch PN
15163633. </P>
.</P>
Please follow this diagnosis process thoroughly and complete each step. If
the condition exhibited is resolved without completing every step, the remaining
steps do not need to be performed. If these steps do not resolve the condition,
please contact GM TAC for further diagnostic assistance. This diagnostic
approach was developed for the vehicle with the VIN you entered and should not
be automatically be used for other vehicles with similar symptoms.</P><A
name=ss3-1478805><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1478805&psdid=732&evc=sm#ss3-1478805">
<H5>Models:</A></H5>
(04 Hummer H2) </P>
.</P>
</P>
<TABLE width="100%">
<TBODY>
<TR>
<TD align=left width=778><FONT size=1>GM bulletins are intended for use by
professional technicians, NOT a "do-it-yourselfer". They are written
to inform these technicians of conditions that may occur on some vehicles,
or to provide information that could assist in the proper service of a
vehicle. Properly trained technicians have the equipment, tools,
safety instructions, and know-how to do a job properly and safely.
If a condition is described, DO NOT assume that the bulletin applies to
your vehicle, or that your vehicle will have that condition. See
your GM dealer for information on whether your vehicle may benefit from
the information.
</FONT></TD>
<TD align=middle width=42></TD>
<TD align=middle width=167><FONT size=2>WE SUPPORT VOLUNTARY TECHNICIAN
CERTIFICATION
</FONT></TD></TR></TBODY></TABLE>
<P align=center>© Copyright General Motors Corporation. All Rights
Reserved.
</P>
<FORM name=bottomNavForm>
<HR>
<TBODY>
<TR>
2004 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM></BODY></HTML>
