Old 06-26-2005, 02:46 PM
Lean Machine's Avatar
Lean Machine Lean Machine is offline
Lean Machine is off the scale
I was given a set of chrome side marker light bezels so I decide to use them. What is the simplies way to install these? The two on the side of the hood were simple because you could disconnect the light from the inside and thread through the bezel before re-attaching. The two near the truck seem to be more difficult. I can't just disconnect the lights from the inside. There must be a easier way
\'05 H2 Lux Pewter SUV, Nav, Air, Sunroof, 22x10 E Forged EF16 with BFG Limited Edition Mud-Terrain T/A 335/55R22 and varies Chrome Parts
\'08 H2 Lux White SUT with Sedona interior - SOLD
\'08 H2 Lux White SUT with Sedona interior and 6'' Fabtech Lift
Old 06-26-2005, 04:09 PM
SOFTTAILJC's Avatar
SOFTTAILJC SOFTTAILJC is offline
SOFTTAILJC is off the scale
lean,,, depends what type bezel.. some have a H2 bar in the center...mine didn't and i could sneak the rear markers through kitty corner...then us some rolled foam tape (used for insulating windows, found at home depot) to line the back side of bezel.. makes for a water tight seal... and change those black screws for stainless,,, i even polished mine on a wheel...finishes it off nicely.....soft..
Old 06-26-2005, 05:45 PM
Thanks Soft. I had a feeling I was making things more difficult than they had to be. I didn't even think to do something to make a water tight seal. Thanks again
