Old 09-30-2005, 07:00 PM
GeorgeSSSS's Avatar
GeorgeSSSS is off the scale
Friends:
I'm considering buying a Pull Pal for all the usual reasons. However, I noticed one internet article saying the Pull Pal is intended to assist moving wheels, not anchor a dead weight pull. If that is true, and you are truly stuck, does the Pull Pal make any sense? I must be missing something here and would appreciate members' input.
I've always gotten outstanding advice from you gents and ladies, so I'm asking for more.
Best regards,
George SSSS
GeorgeSSSS's Avatar
Friends:
Best regards,
George SSSS
Old 10-01-2005, 12:10 AM
Arizona Hummerboy's Avatar
I got to see and use the Pull Pal RW 11000 frist hand, at the Hummer Driving Academy. We had A H2 SUT all 4 tires buried in sand/dirt, you could open the door and step right out onto the ground, we were stuck.
We hook up to the Pull-Pal, we started to winch and the Pull-Pal set it's self deep into the ground right away, and we winch the rig out of the sand/dirt with no problems.
And the Pull-pal was very easy to remove from the ground, all we did was pull up on the end of the Pull-Pal and it came right out of the ground.
I do have the Pull-Pall RW 11000 for my rig.
Dwayne
Hummer Driving Academy " Graduate "
Class
August, 05
Old 10-01-2005, 10:34 PM
GeorgeSSSS's Avatar
Guys:
Definitely solid information. I'm going to get one. Two questions:
1. When you use it, are you turning the vehicle's wheels?
2. How do you transport yours? I have a Gobi stealth rack on my rig. I saw some brackets on the internet. Do either of you use one of them?
Thanks,
George SSSS
Old 10-02-2005, 01:51 AM
I just carry mine in the back of the Hummer along with my Hi-Lift Jack. Mine is still in the box.
I am thinking of making a mount on the roof basket to hold it.
I read on the net somewere that the Pull-Pal will fit into a gun case bag.
Old 10-02-2005, 02:57 AM
GeorgeSSSS's Avatar
Outstanding. Now I'm all set.
Thanks again,
George SSSS
Old 10-03-2005, 01:48 AM
George
I just bought a Hard Plastic Gun Case, from Wal-Mart for $21.95 .
The Pull-Pal fit perfect in side of it.
Old 10-03-2005, 11:57 PM
GeorgeSSSS's Avatar
Outstanding. Is it a standard rectangular case or something else?
Old 10-04-2005, 02:21 AM
It is a hard rectangular case, it was made to hold two shotguns.
And the Pull-Pal fit it just perfect.
Old 10-04-2005, 03:40 AM
rodster rodster is offline
rodster is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Arizona Hummerboy:
And the Pull-Pal fit it just perfect. </div></BLOCKQUOTE>
Couldn't find the product on walmart.com but did find this case . Is that about the same thing? Do both parts of the Pull-Pal fit inside?
Thanks much.
\'05 SUT
Old 10-04-2005, 01:11 PM
Here is some pictures of the Case and Case with the Pull-Pal inside of the Case.
The size of the Case is 52"L x 4" D x 11" W
Old 10-04-2005, 01:13 PM
Picture # 2
Old 10-04-2005, 01:15 PM
Picture # 3
Old 10-04-2005, 01:20 PM
The spade part is a projectile waiting to happen and that case is a terrific solution! Thanks for the pics.
\'05 SUT
Old 10-04-2005, 01:28 PM
VernB VernB is offline
VernB is off the scale
Now I know what color Hummer to look for on our next Hummer event.
Old 10-04-2005, 01:50 PM
The case works great. The spade was the hard one to try to find a place for in the Hummer.
I removed the top foam from the case, so the top would close better, it was a little tight.
With the case I can now mount it to the Roof Basket, for runs and then remove it after runs.
Old 10-04-2005, 01:56 PM
VernB
My Hummer is easy to find. I have custom window screen on the side. And Awesomesuccess on the front windshild and on the back window.
