10-03-2004, 10:53 AM
Mine will not hold its memory for the EQ it keeps going back to driver and I set time after time .Also my Drivers mirror goes north not sound when i put it reverse, the easy exit in and out doesnt work .Ive tried to reset both drivers 1-2 and no luck D2 does work on the mirrors, ANY help let me know , chris
10-03-2004, 11:35 AM
You're not making very much sense in what you are saying. For starters, pick up the owners manual, and read it twice about how to set all of these personalization things. You'll probably find that will take care of your problems. For the mirror in reverse for example. Make sure the option for it is turned on to move in reverse, then, start it up, put it in reverse, let it move. Then while still sitting in reverse, move the mirror to the position you would like it to go to while in reverse. Then put it back in park. This should set your mirror to then go to that position.
10-03-2004, 01:40 PM
Does your seat move back to position? Sounds like driver memory problem. Whenever mine act up (3 times in 8 months so far), seat will move all the way forward, radio, mirror messed up. Bring to dealer to change module + UPDATED PROGRAMMING!
10-03-2004, 03:26 PM
Just to update you on the memory seat module problems. Gm is updating it again, and the latest one is suppossed to be out at the end of the year. And this is suppossed to finally take care of all memory seat problems they've been having.
10-03-2004, 03:34 PM
Many of the memory items, (perhaps all ?), will ONLY remember the position if you are in the PARK position of your transmission. I was having that same sort of issue, until I finally read the manual.
I know it is stupid, it doesn't work like any of my other cars that have the memory options. For those others I just activate the "remember this" button sequence, which might be holding the Drive# button for more than a couple of seconds to then hear a "beep" (like the H2 does) or first pressing a Memory button and then the desired Driver# (like my BMW and my Jeep GC).
It is only the Hummer that requires me to be in the PARK position. Weird, but once you learn that...
\"I asked my wife for a hummer, she gave me this H2.\"
03 White H2 Adventure, sunroof, Garmin GPS, Air Horns, Diablo Sport Programmer
10-03-2004, 05:45 PM
Hummertech
Hummer Novice, Sorry Im not that stupid Ive went through it more than once .My two close friends have H2 WITHOUT THE PROBLEM . I live 100 miles from the dealer so it is hard to get there. What part do you not understand. IT used to work .Ive set them off and on NO LUCK . Ive tried to set themboth no luck.To the others Thanks for the help, chris
10-03-2004, 05:47 PM
H2Finally , Thanks for your help Mine has done that before.I will get it to the DR. and get it looked out
