Old 02-05-2003, 10:22 PM
H2 Vette H2 Vette is offline
H2 Vette is off the scale
Is the radio opening in the H2 double DIN or DIN 1.5? If it is Double DIN is any modification needed? Also, what do you lose if you totaly remove the factory stereo and what are the benefits to relocating the factory stereo (underneath a rear seat)with a complete aftermarket setup?
Old 02-06-2003, 01:12 AM
JohnnyBoy JohnnyBoy is offline
JohnnyBoy is off the scale
There are some posts regarding what can be done with the factory stereo. I believe if you remove it completley you will lose the steering wheel functions to control the stereo. What has been recommended is to leave the factory stereo hooked up and left behind the dash (apparently there is room) and then install the aftermarket deck.
I hope this helps a little.
03 Hummer H2 Adv./Lux. Pkgs. Sunset Orange W/Sunroof
Air Spring Susp. Pkg. + 3rd. row seat
http://www.haugens.com
\'03 Hummer H2 Adv./Lux. Pkgs. Sunset Orange W/Sunroof
Air Spring Susp. Pkg. + 3rd. row seat & DVD System.
CompuStar Auto Security/Remote Starter.
Old 02-06-2003, 01:52 AM
AUBURN H2 AUBURN H2 is offline
AUBURN H2 is off the scale
Hey,
The radio opening is double DIN and there is plenty of room to do what you want in the dash. If you swap the radio out you can add an apaptor to maintain the steering wheel controls. You will need to keep the circuit board out of the radio only, this is required to keep the Onstar functioning. The radio is very modular and the circuit board can be removed very easily. Just wrap it up and place it inside the dash behind the new radio.
Old 02-07-2003, 01:27 PM
Jonathan Jonathan is offline
Jonathan is off the scale
Actually, you don't need any of the radio. There is a piece from a company called Peripheral that makes a steering control adapter and an the GM Onstar adapter. This way the entire factory radio and amp can come out and become a tire chaulk.
Jonathan Frank
Anderson Audio & Performance
404-867-2564
Jonathan Frank
404-867-2564
Old 02-07-2003, 04:47 PM
hinten hinten is offline
hinten is off the scale
Which one would that be?
Everything I have read so far there is no updated version available for the H2.
Couldn't find anything on their sites:
http://peripheralelectronics.com/2002/home.asp
