12-10-2005, 05:27 AM
hi
another question.
in germany i take the fuel "super bleifrei" with 95 octane
is that wrong?
what fuel do you think i have to give my hummer h3 ?
we only have "normal" with 91 octane .. that is the cheapest :-)
thanks for replay
carsten
h3 with luxury pack, black leather, chrome all over, monsoon speakersystem... and my english bulldog \"dimba\" on my side :-)
hi
another question.
is that wrong?
thanks for replay
carsten
12-10-2005, 05:37 AM
The cheap stuff is fine here. 91 octane is just fine for you guys I am sure.
Heck, I think the H3 will run on Tang if you get the mix just right.
12-10-2005, 09:57 AM
I put Shell 87 octane in mine as recommended, it runs great and I save a few $$$.
12-10-2005, 11:17 AM
Europe uses only the research octane number (RON), while in the US, we use the average between the research octane number (RON) and the motors octane number (MON). That's why on our pumps you see (something like), R+M/2.
Research number is derived from iso-octane and motor is derived from n-heptane, and research is the higher of the two numbers. RON is figured on a test that simulates fuel performance under low operating speeds (600 RPM I believe), while MON simulates high speed (9-1200 RPM). It is primarily a tool to compare fuel at a pump from different distributors.
In Europe they only use the research number. As a general rule of thumb, subtract 4 from the European octane rating and you have what the R+M/2 number would be in the US.
(NOTE: I say European, but it is primarily the number used in all countries but the US. Similar to the metric system that we have failed to adopt officially.)
12-10-2005, 11:34 AM
I usually end up putting in 87 octane. No problems
12-10-2005, 01:36 PM
bparker, don't let "W" find out we know how to run Tang in our H3's. The price will double at grocery stores across the nation!  Shhhhhh...
____________________________
12-10-2005, 08:37 PM
My bad bud... =)
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Mike E:
bparker, don't let "W" find out we know how to run Tang in our H3's. The price will double at grocery stores across the nation!  Shhhhhh... </div></BLOCKQUOTE>
12-14-2005, 04:01 AM
I run 91, it makes it go faster
