Old 11-12-2004, 06:28 PM
falcon falcon is offline
falcon is off the scale
I bought an H2 factory Navigation after installed it's display theftloc I called my dealer and they said it's can't be done. Can some one help me out please Thanks
Old 11-12-2004, 07:07 PM
Klaus's Avatar
Klaus Klaus is offline
Document ID# 1275527
Radio Setup With RPO UM8
Radio Theft Procedure
Complete the following procedure, using a scan tool, in order to properly set up communication:
1. At the Main Menu screen, select: Diagnostics.
2. At the Vehicle Identification screen, select the following options:
Model Year
LD Trk, MPV, Incomplete
3. At the System Selection Menu screen, select: Body
4. At the Vehicle Identification screen, select the following:
Appropriate model
Appropriate Air Conditioning
Navigation Radio
5. At the Body Screen, select: Navigation Radio.
6. At the Radio screen, select: Special Functions.
7. At the Special Functions screen, select: VIN Relearn.
8. At the VIN Relearn screen, the scan tool will display "Do you want to clear radio theft information?"
9. To begin clearing, press the soft touch key on the top right of the scan tool. The scan tool will display "Clearing Radio Theft in Progress."
10. Press EXIT on the scan tool and cycle the ignition.
Important
The radio theft will learn the VIN. Without learning the VIN, the radio will display a locked message (LOC or LOCKED).
Old 11-13-2004, 08:55 AM
intimidator intimidator is offline
intimidator is off the scale
to unlock the 2004 navigation radio in a 2003. the technician has to build the vehicle as a 2004 on the tech2. because if built as a 2003 there is no option for navigation radio in the tech2 software for 2003 because the nav radio wasn't available in 2003. hope this helps and yes it can be done because i did it myself.
Old 11-15-2004, 01:06 PM
Does any body in Chicago can reset it for me? I have call me dealer and they can't do it. thanks
Old 11-15-2004, 09:10 PM
go to any gm dealer. if they won't do it. grab a technician and slip em 50 bucks.if ya want to drive to philly i'll do it.
Old 09-11-2010, 12:42 AM
Xotik H3 Xotik H3 is offline
Xotik H3 is on a distinguished road
Default Re: Help H2 Navigation
This is a really old thread but a damn good one. I went today with the instruction to my dealer who siad it cannot be done.
They followed them step by step, and set my 03 as an 04 in the tech 2. It worked perfectly!!
I really enjoyed the look on the shop supervisors face when the radio came on after he told for 10 minutes why it would not work
