Old 10-25-2003, 03:32 AM
aces full aces full is offline
aces full is off the scale
Has anyone solved the "missing" AUX INPUT problem for the OEM sound system? Still trying to find a way to hook up an IPOD without FM modulation.
'03 Black H2, fairly dressed up,
'03 Powerstroke Diesel 4x4 Excursion,
'04 Red & Black Mini Cooper (on order),
'02 Black Honda Goldwing
\'03 Black H2, fairly dressed up
\'00 Black Mercedes S430
\'03 Mineral Grey Powerstroke Diesel 4x4 Ford Excursion
\'02 Black Honda Goldwing
Old 10-30-2003, 11:41 AM
Dreadnought Dreadnought is offline
Dreadnought is off the scale
I have an Archos AV380 80GB multimedia device I want to use in my H2 http://www.archos.com/products/prw_500569.html
Great piece of hardware!!!
This is a reply I got from Delphi (makers of both the Integrated stereo/six disc CD changer and the '04 nav-system) : "The AUX inputs are pre-defined by GM and not accessible by any aftermarket device. You cannot add anything to this system through auxiliary inputs that have not been pre-defined by GM. Our navigation systems are currently only available as factory-installed options on new cars. The nav system is not available to install as an aftermarket product or an upgrade."
Of course I knew this would be the answer, and I also know I'll probably have to resort to Pac :-| or FM-modulation :-(
What about using the sound input from the Onstar box? Here in Norway we cannot use Onstar anyway. If I only could figure out how to "activate / deactivate" the input on those input lines (prbly just a current on a 3rd connector). Any ideas?
Snowing here now! KEWL!
Old 10-30-2003, 02:38 PM
2slo4now 2slo4now is offline
2slo4now is off the scale
nothing out there yet. The unit has been promised for a year and it is still not available. FM modulator is your only option at this time.
Dan from Alabama
Old 10-31-2003, 11:04 AM
Found something:
http://www.pie.net/sec12sb1d.htm
GM9-MFF
ONSTAR™ COMPATIBLE "Y" HARNESS
GM12-MFF
Now I only need to adapt to the GM audio unit plug. Anyone?
Old 10-31-2003, 11:19 AM
BTW: Is it the 9pin or 12pin I need? I removed the center console last december to look for AUX inputs (I could not _BELIEVE_ there was none; Aaargh - US products sometimes!), and I'm not gonna do that in vain again.
