Old 08-26-2005, 02:19 PM
Talked with 4 wheel parts Denver today.
The 4" rancho susp. lift is avail. Sept 15th for $3400 plus tax installed. The kit is complete with the exception of shocks.
They have the Rancho 9000 adj. for those.
They say with propr rim/ tire fitment, 37" tires will fit. OMG. I don't think I'd do 37's though. 35"S on a 4" will look good.
Old 08-27-2005, 01:54 PM
FormerJeeper FormerJeeper is offline
FormerJeeper is off the scale
Are they serious?
It's got fawkin leaf springs in the rear so the cheapest and easoest way is to use an extended length shackle in the rear.
Total cost $100.
Now, I'm sure an IFS front end lift doesn't cost $3500!
Personally, I'm going to put a 1" body lift on, tweak the torsion bars and fit 35s without any suspension mods.
-C
Old 08-27-2005, 02:07 PM
This is all FabTech do to get 3 or 3.5" lift with a Chevy Colorado.
http://www.fabtechmotorsports.com/html/chevy2wds10.html
It's a new spindle, new shackle, extended brake lines and new shocks.
Probably costs less than $750 for the whole thing!
Beware H3 owners, accessory manufacturers are going to try and rape you like they do to H2 owners
-C
Old 08-27-2005, 02:37 PM
H3 Guy H3 Guy is offline
H3 Guy is off the scale
FormerJeeper, have you ever put shackles on a leaf under axle? The H3 is already feels like the rear is on a skateboard. If your looking for a performance upgrade, leafs are the way to go.
Old 08-27-2005, 02:49 PM
MxHonda MxHonda is offline
MxHonda is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by FormerJeeper:
-C </div></BLOCKQUOTE>
That is for 2wd not 4wd...
\'06 H3: Slate Blue, Lux Cashmere, OffRoad, Auto, Sunroof, XM, Rails, Racks, and Guards.
Old 09-01-2005, 12:46 AM
FYI...
http://www.gorancho.com/products/sus...s/hummerH3.stm
Old 09-01-2005, 03:32 AM
DeLeon DeLeon is offline
DeLeon is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by H3 Guy:
FYI...
http://www.gorancho.com/products/sus...s/hummerH3.stm </div></BLOCKQUOTE>
Any idea how much $ that is?
\'06 Boulder Gray H3 / Loaded
Old 09-01-2005, 04:12 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">FormerJeeper, have you ever put shackles on a leaf under axle? The H3 is already feels like the rear is on a skateboard. If your looking for a performance upgrade, leafs are the way to go. </div></BLOCKQUOTE>
Why would it make any difference if the leaf pack was under the axle or above it?
Is there too much curve or something?
-C
Old 09-06-2005, 04:56 PM
jagular7 jagular7 is offline
jagular7 is off the scale
If you read over Ranchos suspension lift kit, it leaves the torsion bar crossmember in it's stock location. There are drop brackets for the lower control arms, a cradle to house the diff, elongated knuckles for retaining the stock r&p steering and stock upper arm location, and supporting struts for the lowered cradle/drop brackets. They are adding new leaf packs for the rear suspension.
Jagular7
Come visit: http://www.ksrockspark.com/
Old 09-06-2005, 05:03 PM
With leaf springs, the will be inherent axle wrap. This occurs when the pinion whats to walk around the ring gear in the housing. The tendency is to have the pinion rotate upward for forward motion. With the leafs on top of the axle, the rotation of the axle is not limited in comparison to the leafs mounted under the axle. They both will walk, but it's the mounting under with the lesser of the 2 choices. That's why, when lifting most spring-over vehicles, lift is added with spacer blocks. This creates larger spacer between axle centerline and the center of the spring, the bigger the rotation arm.
Jagular7
Old 09-11-2005, 01:54 AM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
They say with propr rim/ tire fitment, 37" tires will fit. OMG. I don't think I'd do 37's though. 35"S on a 4" will look good. </div></BLOCKQUOTE>
Timgco, installed by whom? Will the dealer sell and install it and give warranty?
2003 Yellow H2 LUX (Sold)
Old 09-12-2005, 01:47 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by kacyk:
Timgco, installed by whom? Will the dealer sell and install it and give warranty? </div></BLOCKQUOTE>
4wheel Parts Denver would do the installation.
It will void any susp. warranty through GM f the dealer does not do it. However, talk with you service manager and get his answer in writing if you plan on havingthis done. Chances are, if they are willing to do the instaltion for you, they will extend some type of warranty.
Old 09-15-2005, 06:09 PM
hummer dude hummer dude is offline
hummer dude is off the scale
rancho lift on the ARIES H3
Old 09-18-2005, 03:43 PM
jp's-h3 jp's-h3 is offline
The 4wheel parts in Salt Lake quoted me $2,280.99 for the Rancho kit, $3,100.00 installed. includes tax. and $300.00 for a optional 3 year extended warranty that covers all of the Rancho suspension components and installation of the components.
I'm torn, should I go ahead and do it, or should I wait for other manufacturers to introduce their lift's and hope the price go's down?
Old 09-18-2005, 07:08 PM
kacyk's Avatar
That seems to be a great price. I'm conflicted because I want the factory warranty. Who knows what the dealer will not cover due to the suspension upgrade.
Old 09-18-2005, 08:40 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by jp's-h3:
I'm torn, should I go ahead and do it, or should I wait for other manufacturers to introduce their lift's and hope the price go's down? </div></BLOCKQUOTE>
DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT
I think............ you should do it!
But ask a little more about the warranty and ask if it cover where the dealer will no longer cover.
OH YEAH! GET IT DONE! ...within the next three weeks too.
