Old 09-01-2004, 02:16 PM
1BADH2 1BADH2 is offline
1BADH2 is off the scale
My check engine light went on yesterday after I got on it to pass someone, I'll take it to the dealer,its got 32k on it any ideas what it might be?
Old 09-01-2004, 03:25 PM
Texas Red's Avatar
Texas Red is off the scale
I have 20,000 miles. I have tromped on the accelerator a couple of times lately, but no "check engine" light came on. Keep us posted.
Jim
2008 H3 Graphite Lux
Old 09-01-2004, 04:37 PM
Orbital H2's Avatar
Orbital H2 is off the scale
I was going through the Sepulveda pass at abouit 80 MPH, stepped on it to keep up my speed, it down shifted 2 geers, then the light came on. dreove another 50 miles, shut it off for 30 min, light still on, let it sit for a couple of days it then wnet away. I have no idea why, but it hasn't come backon.
Old 09-01-2004, 05:44 PM
H2 Bill H2 Bill is offline
I did that the other day and all of my dash gauges went off but the check engine light didn't come on....I stopped and turned the ignition back on and everything was back to normal..strange.
1994 Chev Suburban Blown
Old 09-01-2004, 06:06 PM
discofever discofever is offline
discofever is off the scale
1BADH2,
It could be the type of GAS you’re using… or your gas cap may be loose… (usually #1 reason for check engine light)
Did you fill up Costco Gas? The check engine light on my past vehicle would always turn on after filling up at Costco. ****ty Gas…
Old 09-01-2004, 06:27 PM
I checked the gas cap and it was loose,(I feel like a moron ) the light is still on but maybe it will go off soon. I'll keep you posted.
Old 09-01-2004, 07:15 PM
B UNITT B UNITT is offline
B UNITT is off the scale
you probably need to reset the computer...just unplug the positive battery terminal for about 10 minutes...then plug it back in..problem solved
Brian
Old 09-01-2004, 07:28 PM
Dan Dan is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by 1BADH2:
...any ideas what it might be? <HR></BLOCKQUOTE>
It means you need to Check the Engine.
Old 09-01-2004, 07:34 PM
Since the gas cap was loose, it will take a few miles for the computer to reset itself... Do not worry, it will do it on its own... No need to rush to the dealer on this one...
PS. Yes, it has happened to me too!
Discofever!
Old 09-01-2004, 07:43 PM
Hummer Man is off the scale
Discofever is right on the money. You can replace the cap with engine on or off but restart the engine and it will go through the diognostics check in the first second.
Old 09-01-2004, 08:31 PM
intimidator intimidator is offline
intimidator is off the scale
the light will reset after 3 drive cycles.a drive cycle consists of driving the vehicle a ninimum distance of 15 miles then letting it cool down completely. so in 3 days the pcm will have ran all of the obd2 tests and when it sees it pass it will turn off the mil lamp.pcm=powertrain control module.mil=malfunction indicator lamp.
iv'e been a gm tech for 20 years.
Old 09-01-2004, 09:32 PM
Albie's Avatar
Albie Albie is offline
Albie is off the scale
I am driving my old car with the check engine light on. It been like that for the last 70k and now I am at 260k.
Old 09-02-2004, 01:32 PM
Albie, that only means that the gas cap is not the problem... We that many miles, I have a suspicion that your check engine issue will be the oxygen sensors on your exhaust between the exhaust manifold prior to the catalyst converter.
Old 09-02-2004, 06:04 PM
Albie's Avatar
the problem is that I have only 18 psi in one the of the Cylinders.
