Old 02-03-2006, 08:46 PM
boomer boomer is offline
boomer is an unknown quantity at this point
i got brave and tweeked the torsion bar 2.5 turns. i gained about an inch and a quater. when i checked the distance from wheel to fender there was a quater inch differance from one side to the other.this was before i did any ajusting. didnt know if i should turn torsion nut to make even or leave it
Old 02-03-2006, 09:48 PM
HummerLV's Avatar
HummerLV HummerLV is offline
HummerLV is off the scale
i would go even
Old 02-04-2006, 12:18 AM
StarsnBars's Avatar
StarsnBars is off the scale
Drive it first, Hit a couple of bumps then re measure it,, also where you parked on a level area? That might of been the difference. Do 2-1/2 turns then drive it and check it again. It should be level unless it wasnt set-up right from the factory. If its still off make the adjustment on one bolt to even it up... See ya
