Old 07-21-2005, 08:45 PM
H3 Hummer's Avatar
H3 Hummer is off the scale
I have read several posts here and other sites in regards that the grill plate bolts are missing. One post stated the plate fell off! Just for clarification, I am referring to the protective "plate" directly behind the front bumper and below the oil pan / engine.
I recently went to install new undercarriage protection, the other day and the instructions say to remove the current bolts. Well those current rear bolts were not there. Also, on mine only one of the front bolts were on there. I had to go purchase new ones. This is obviously some mistake and potential big issue.
Climb under your rig or even look from the side and see if your bolts are attached to the rear of your skid plate. They are about 2 inches long bolts size 13 mm socket.
I hope to add a picture soon.
H3 Hummer's Avatar
Old 07-21-2005, 09:25 PM
H3 Builder's Avatar
H3 Builder H3 Builder is offline
H3 Builder is an unknown quantity at this point
I alerted the quality department about this issue and they are checking into this problem. Evidently the 2 middle bolts are hand started in one part of the plant and are used as guides for the other 2 plates to go into position, then all are suppost to be tightened down durring the final assembly. I may need some vin numbers from some of you to help find out where the process has fallen short. This is the last thing anyone at our plant want is problems with your H3 and want this problem fixed. Thanks to all who have said that this has happened so we can track down this problem.
Old 07-22-2005, 11:12 AM
jkH1+H2=H3 jkH1+H2=H3 is offline
jkH1+H2=H3 is off the scale
hey guys, so I crawled under my H3 last night a pulled and did everything possible to see if the plate was loose, or coming loose? so far so good, then I proceeded to see if I could bench and lift the h3, my success was about a 1/8 of an inch of suspension lifted.
Have fun going to drive my H3. Also, Got Bling on mine the Sma hood handles are awsome!!
Old 07-22-2005, 04:24 PM
HummerJim's Avatar
H3 Hummer GREAT PICTURES of your red Hummer at Long Beach! Those are good enough that Hummer could use them in their brochure. The girl in the H3 is nice too I downloaded the one of your H3 with the surf in front for a screensaver!
Old 07-22-2005, 04:35 PM
wannabeH3's Avatar
yeah i lost one bolt.. i should try to bench press my H3 too....
(with insurance)
Old 07-22-2005, 06:41 PM
H3 Hummer's Avatar
Thanks HummerJim. I will have some more picture of accessories on their soon.
Old 07-23-2005, 02:02 AM
Jersey Guy Jersey Guy is offline
Jersey Guy is off the scale
THE FIRST THING I DID WHEN I GOT MINE HOME WAS CHECK THE SKID PLATE BOLTS NO PROBLEM THEY WERE TIGHT
