Old 04-16-2005, 12:21 PM
ira ira is offline
ira is off the scale
does anyone know how to make those power outlets acc or ignition switched?
i noticed that those outlets are always powerd.
i use fm transmitter for ipod and i want it to be turned off as i turned off the key.
i really dont like to pull it off every time i get out the car and put it back on evry time i get in.
if i have to rewire to feed acc power to the outlet curcuit, where is the best spot to do it so i dont have to rewire all 6 outlets?
2004 h2 black
ira ira is offline
2004 h2 black
Old 04-17-2005, 01:05 PM
LasVegas LasVegas is offline
LasVegas is off the scale
Try this, it may help;
http://www.*******club.com/tech/12v.html </div></BLOCKQUOTE>I believe your outlets are 30 amp circuits and this switched circuit is rated at 10 amps I think. If you use it just be careful what you plug in.
Jonahs
Old 04-17-2005, 06:16 PM
tower's Avatar
tower tower is offline
You can switch the source for all accessory ports to a fused IGN tripped relay or solenoid which controls a hot lead off the battery. Here is the factory schematic.
http://elcova.com/groupee_files/atta...89_TifToGif13_(Medium).gif?ts=4262C30B&key=217FD5D92B3ADAC6F115E A87E5682849&referrer=http%3A%2F%2Felcova.com%2Feve %2Fubb.x%2Fa%2Fga%2Ful%2F6291078401%2FTifToGif13_% 28Medium%29.gif
