Old 07-10-2005, 05:17 PM
H3H H3H is offline
H3H is off the scale
Hi I'm new to the forum. I have a yellow adventure package H3 and want to lift it about 4-6 inches and stick some 35 bfgs on. Any kits on the horizon?
H3H H3H is offline
Old 07-10-2005, 10:18 PM
FormerJeeper FormerJeeper is offline
FormerJeeper is off the scale
You should be able to add a body lift to fit 35s.
The difference, wheel well and rub wise is only an inch afterall.
-C
Old 07-11-2005, 08:54 PM
H3H H3H is offline
I'd also like to get the ground clearance to about 12 inches...
I don't even think that there are any body kits out yet for the h3, nevermind suspension lifts...
Old 07-11-2005, 11:52 PM
mudderducker's Avatar
mudderducker mudderducker is offline
mudderducker is off the scale
you should try to put 35's on now, they might fit.
_____________________
Land Rover Convert - H3 ADV
http://www.deltawaterfowl.org/
http://www.ducks.org/
http://www.joincca.org/
Old 07-12-2005, 01:47 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by H3H:
I don't even think that there are any body kits out yet for the h3, nevermind suspension lifts... </div></BLOCKQUOTE>
Than you'll have to put 37's on there to get that kind of GC. Than you'll need about a "six" to make them work... not to mention LOTS of upgrades to handle those meats. Would be cool to see, but big bucks I would think.
Old 07-12-2005, 02:48 AM
http://performancelifts.com/cgi-bin/cart/PER10153.html
Old 07-12-2005, 04:48 AM
DeLeon DeLeon is offline
DeLeon is off the scale
I can't believe you are considering a body lift.. you should just want for a good suspension lift kit, they should be available in a couple of months.
\'06 Boulder Gray H3 / Loaded
Old 07-12-2005, 01:32 PM
Body lifts are fine so long as you keep them under 2". This minimises stress on the mounts and t-case linkage problems etc.
On Jeeps we used to do 1" body lift + 1" motor mounts + a suspension lift rather than just a suspension lift.
Given that the H3 has leaf springs in the rear, you could probably install some form of poly bushing up front and a larger shackle in the rear and get a simple "budget boost" 2" lift without a bodylift, if you prefer?
-C
