12-19-2005, 06:36 PM
and the front left tire rubs now.
Seriously, anybody ever figure out how to fix these things? You push on the wheel to unbend the axle and the whole thing spins around inside the axle housing. It's completely non-servicable, riveted shut. Real cheap engineering I guess I gotta go plunk down for a new one
'03 pewter base H2
'03 pewter base H2
12-19-2005, 06:50 PM
Need a pic of the underside with it up on the rack
12-19-2005, 06:57 PM
Maybe I should drill it.
'03 pewter base H2
12-19-2005, 06:58 PM
Note: it's a '98 model so don't give me any service directions for the 99 or later.
'03 pewter base H2
12-19-2005, 09:42 PM
looks like a tie rod problem. there you go. my insightful and witty analysis is complete.
oh i now type like ee cummings.
12-20-2005, 01:18 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MUH_HUM:
oh i now type like ee cummings. </div></BLOCKQUOTE>
Nope. It sure looks like a tie-rod. But got it apart and no tie-rod in sight
'03 pewter base H2
12-20-2005, 01:22 PM
Ree...I'm beginning to think that you may have too much time on your hands.
12-20-2005, 01:32 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HIHUMMER:
Ree...I'm beginning to think that you may have too much time on your hands.  </div></BLOCKQUOTE>
Working from home, called into a stupid meeting
Plus I'd do nearly anything for the kid
'03 pewter base H2
12-20-2005, 02:26 PM
You just need an alignment. Simple fix, really.
12-20-2005, 02:54 PM
I can tell by that last picture that you were definitely out of blinker fluid...
Shadow Metallic Green \'06 H3 - chrome appearance - black rails - marker lights - brush guard - Hummer eating dog security system -Mesa/Boogie amplification - BC Rich guitars
http://www.RIVETHEADonline.com
12-20-2005, 03:03 PM
Phew! Got'er back together.
Drilled out the rivet bodies and fit some tiny screws in. Questioned the strength of the connection and supplemented with epoxy
I considered a tack weld with a minitorch, but I'll see how this holds first
If it happens again, I'll have to look into whether Fabtech or someone else has a stronger replacement axle rather than that flimsy Chinese thing
'03 pewter base H2
12-20-2005, 03:05 PM
Axle's straight now and the blinker fluid's topped off. No more rubbing.
Mucho satisfying.
Unfortunately, it still needs an alignment. It drifts left when you take your hands off.
'03 pewter base H2
12-20-2005, 03:22 PM
Congrats on the fix. I feel so much better now.
12-20-2005, 03:40 PM
... I feel so much better now.  </div></BLOCKQUOTE>
What? Knowing that you're not the only one to play with toy trucks?
http://elcova.com/groupee/forums/a/t...1/r/4291029441
'03 pewter base H2
