Old 10-01-2005, 12:27 AM
RazM's Avatar
RazM RazM is offline
Hey guys, this is truly weird and I can't imagine why this is happening. A few weeks ago I went to a local Home Depot, parked and tried to lock the doors with the keyless remote and it didn't work. Tried a few more times, still didn't work and had to manually close the doors. I come back out, try to unlock them, still doesn't work. Drive out of the Home Depot mall, go to a gas station and tried to lock/unlock them, worked perfectly. Everything has been fine since then, until tonight. This time it happened again at the same Home Depot, except it wasn't the keyless that didn't work, the instrument panel wasn't working (no lights, and none of the gauges worked). I drive out and get out of the vicinity of the Home Depot and the whole instrument panel started up and is working normally.
Does anyone know what is going on? The only problems I've had with the H3 have been around this damn Home Depot, is it cursed or an environmentalist Home Depot? lol
Any help would be appreciated, thanks!
RazM's Avatar
Old 10-01-2005, 12:34 AM
Johan Johan is offline
Johan is off the scale
I'm thinking "aliens" here. Were there any crop circles in the immediate area?
Old 10-01-2005, 12:45 AM
jkH1+H2=H3 jkH1+H2=H3 is offline
jkH1+H2=H3 is off the scale
I heard all Home depots are built on top of Waste dumps,toxic, nuke, garbage, etc. For real that is what I was Told. They only build on none residental properties.
Did your H3 lights come on, unexpected?????
Old 10-01-2005, 03:19 AM
My Tahoe had the locking problem in certain areas near Oceana Naval Air Station. It was very weird.
Old 10-01-2005, 03:37 AM
killian's Avatar
killian killian is offline
killian is off the scale
Bermuda Triangle. Was your compass pointing the wrong way too?
Old 10-01-2005, 05:10 AM
BumM3r's Avatar
BumM3r BumM3r is offline
BumM3r is off the scale
Are there any large antenna's, like TV or radio station types in that area?
05 Pewter Lux SUT, spare tire delete
Old 10-01-2005, 06:01 AM
bparker's Avatar
bparker bparker is offline
Yep, almost all home depots have large cell towers on them or near them.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by BumM3r:
Are there any large antenna's, like TV or radio station types in that area? </div></BLOCKQUOTE>
http://www.tahoeforum.com
http://www.motoforum.com
Old 10-01-2005, 10:22 AM
just what i was going to ask...RF interferrence in some locations can cause this problem. verified it happens to the remote but never heard of the lights since they are hard wired.
How about Lowes?
Old 10-04-2005, 01:43 AM
RazM's Avatar
Thanks for the replies guys.
Yeah my brother mentioned RF interference for the keyless problem, but the instrument panel not working has me stumped. BTW to be clear, the headlights/interior lighting worked, I meant the instrument panel didn't light up and the gauges weren't working.
As for Lowes, we don't have those in Canada
Old 10-04-2005, 04:50 PM
1COOLH3 1COOLH3 is offline
1COOLH3 is off the scale
Next time you go there take both remotes- if both of them won't work than it's probably not a problem with your H3.
If one works and the other doesn't than there probably is a problem with either the remote or the receiver in the truck.
Old 10-04-2005, 05:13 PM
RazM's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by 1COOLH3:
If one works and the other doesn't than there probably is a problem with either the remote or the receiver in the truck. </div></BLOCKQUOTE>
I Actually had both remotes and tried each one, neither worked.
Old 10-04-2005, 05:24 PM
Webb70 Webb70 is offline
Webb70 is off the scale
RazM, where are you located? If the Home Depot is near by I will try my remote on my doors there...
Old 10-04-2005, 08:43 PM
Battlebugs's Avatar
Battlebugs Battlebugs is offline
Battlebugs is off the scale
How about Lowes? [/quote]
Hah - my H2 died at in a Lowes parking lot, had to be flatbeded to the dealer. Had no oil pressure...until it got to the dealer, they agreed there was a fault but could not find the source, after an oil change it went away....weird, some kind of home improvement store Hummer hatred conspiracy???
03 Yellow Adventure
97 SS Camaro SLP Build # 2919
Old 10-04-2005, 08:53 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Battlebugs:
...weird, some kind of home improvement store Hummer hatred conspiracy??? </div></BLOCKQUOTE>
They must all be run by tree huggers
