Old 12-10-2004, 05:15 PM
H2Beast H2Beast is offline
H2Beast is off the scale
Greetings,
I need help. I'm just about closing a deal on a 4 door H2 04, done 8000 miles. I've got some concerns related to the H1 weak points:
- Upper and lower ball joints on the suspension A arms are too weak.
- Transfer case housing is too weak so is the chain inside.
- Brake pads are sizing on the rotors, especially in the front.
- Steering idler arm likelly to break.
- If CTIS equipped, always leaking.
- On gas engines, the fuel tank is subject to melting because the tank is not enough protected from the exhaust. The fuel creates vapor, the vapor dilates the "plastic" tank to such an extreme that the tank would actually touch the exhaust pipe.
- The gear hub will take a lot of play very fast and is too weak to stand any abuse in the rocks or with bigger tires.
How true all is all this?
Hummer H2 2004, Jeep Wrangler Rubicon 2004, Corvette C5 2004. All modified..Check my website for more info.
