Old 07-20-2005, 11:42 PM
HiRoller HiRoller is offline
HiRoller is off the scale
I wonder if anyone has had problems with the seat memory changing from driver 1 to driver 2 on its own randomly. Mine is normally set to driver 1 but I often have to change it back when I turn the key on and it comes up driver 2. I have even disabled key in selection on driver 2.
Old 07-21-2005, 03:40 AM
dochummer's Avatar
I don't know if this will help, but are you using the #2 key fob? That would tell the vehicle that you're the #2 driver, and set the seat to those settings....
If you're driving an older H2, there is also a software fix for the memory not recalling the proper settings...
'03 H2
Old 07-21-2005, 03:59 AM
J J is offline
J is off the scale
i have had the same problem, the dealer told me it was a bad fuse , they fixed it now there are no problems
Old 07-21-2005, 11:58 AM
Hum2's Avatar
Hum2 Hum2 is offline
Hum2 is off the scale
Definitely have had/still do have that issue....I just stopped using the seat controls!
Mine would shove the seat all the way forward when I unlocked the vehicle, so I couldn't get in the seat without sliding it back manually. Resetting never helped.
Ric
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 07-21-2005, 01:32 PM
dochummer's Avatar
Hum2, I had the same issue. They replaced the module once, which didn't fix the problem. But so far, I've gone over a week with the software update, and have had no problems. The seat functions just like it should. Prior to that, it would push the seat up to the dash, every other day or so...
'03 H2
Old 07-21-2005, 01:50 PM
Hum2's Avatar
Thanks Doc! That's mine for sure....guess I should ask for the software update...even though I am used to not using now.
Ric
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 07-21-2005, 11:40 PM
Thanks for the tip. I feel like a bonehead but your right I did have my #2 remote and this is the reason it kept changing when I unlocked it.
Old 07-22-2005, 04:00 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HiRoller:
Thanks for the tip. I feel like a bonehead but your right I did have my #2 remote and this is the reason it kept changing when I unlocked it. </div></BLOCKQUOTE>That's pretty funny! Thanks for admitting it.
Remember to enable that key now.
