Old 12-27-2005, 11:43 PM
MIZZOU H2 MIZZOU H2 is offline
MIZZOU H2 is off the scale
For the last few times it has rained i have found rust comming out from the lugs on my wheels??? the actual wheel i dont believe is what is rusting but im not sure where it is coming from. I didnt have this problem with my old wheels. anyone else come across this problem?
these are my wheels
Drop the zero, grab a hero
these are my wheels
Old 12-28-2005, 02:41 AM
WISH i could help but id be pissed as a mother fukker if that was me
Old 12-28-2005, 11:31 AM
VTSTOMPER is off the scale
you might want to take them off, and scrub your wheel studs. You can put a type of lube that will not allow your studs to freeze up. That would probably help. You could also paint the rusty area of your disc brakes if they are bad!?
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 12-28-2005, 07:44 PM
HGW HGW is offline
HGW is off the scale
What he said--plus it could be cheap lug nuts. You won't know until you take off a wheel and find the source.
Also--are the wheels themselves cast or forged?
Old 12-28-2005, 10:22 PM
Intercooled's Avatar
Intercooled is off the scale
you might want to take them off, and scrub your wheel studs. You can put a type of lube that will not allow your studs to freeze up. That would probably help. You could also paint the rusty area of your disc brakes if they are bad!? </div></BLOCKQUOTE>
The product is called Antiseeze. Works great. My neighbor used it on the lugs of his boat trailer rims. The salt water would sieze the bolts on from backing the boat in all the time. With this stuff he was always able to remove hos rims with no problem.
2006 H2 SUT Fusion Orange LE
Old 12-29-2005, 11:56 AM
Dan Dan is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Intercooled:
...he was always able to remove hos rims with no problem. </div></BLOCKQUOTE>
He said hos
