Old 03-04-2004, 10:30 PM
Klaus's Avatar
Klaus Klaus is offline
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Service Information</TITLE>
<META http-equiv=Content-Type content="text/html; charset=windows-1252">
<META content="Microsoft FrontPage 5.0" name=GENERATOR></HEAD>
<BODY bgColor=#ffffff>
<FORM name=topNavForm action=/servlets/CellHandler>
<TABLE width="100%" align=center>
<TBODY>
<TR>
<TD width="25%" slign="LEFT"></TD>
<TD align=middle width="50%">Document ID# 1464408
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE>
<HR>
</FORM>
<H1>Info - Enabling Memory Seat Feature Via DIC If Inoperative #04-08-50-003 -
(02/26/2004)</H1>Enabling Memory Seat Feature via DIC If Feature Appears
Inoperative
2003-2004 Cadillac Escalade, Escalade ESV, Escalade EXT</P>
2003-2004 Chevrolet Avalanche, Silverado, Suburban, Tahoe</P>
2003-2004 GMC Sierra, Yukon, Yukon Denali, Yukon Denali XL</P>
2003-2004 HUMMER H2</P>
with Steering Wheel Controls (RPO UK3) (standard on H2)</P>
If the memory seat feature appears inoperative, check the Driver Information
Center (DIC).</P>
Many of the memory seat modules that were returned through the Warranty Parts
Center for a condition of inoperative have shown No Trouble Found. The Driver
Information Center (DIC), programmed for Seat Entry and Exit, is set to the
default "Off" mode at the assembly plant.</P>
DO NOT REPLACE THE MEMORY SEAT MODULE.</P>
Perform the following procedure.</P>
<FONT color=brown>
<H4>Important</H4>
The following procedure will need to be completed for each Remote/Key
selection.</P></FONT>
</P>
Using the DIC menu, do the following steps:</P>
  1. <LI type=1>Set the "Seat Recall" to either "At Key In" or "On Remote" based on
    the customer's preference.
    <LI type=1>Set the "Exit Seat" to "On".
    <LI type=1>Adjust the following items:
    1. Memory Seat:
      <LI type=A>Driver's Seat (including the seat back, recliner, lumbar, and
      side wings)
      <LI type=A>Throttle and Brake Pedals (not available on H2 or Silverado and
      Sierra Trucks)
      <LI type=A>Outside Mirrors
      <LI type=A>Radio Station Presets
      <LI type=A>Last Chosen Climate Control System Settings (not available on
      Silverado or Sierra Trucks)
      <LI type=A>Press and hold the "1" or "2" (for driver 1 or 2) button of the
      memory control for three seconds. A double chime will sound to let you know
      that the position has been stored. </LI>
    1. Easy Exit Seat:
      <LI type=A>Press and release the 1 or 2 button or press the unlock button on
      the desired remote keyless entry transmitter. The seat will move to the
      stored memory position.
      <LI type=A>Adjust the seat to the desired exit position.
      <LI type=A>Press and hold the exit button of the memory control (located on
      the door) for three seconds. A double chime will sound to let you know that
      the position has been stored for the identified driver (1 or 2).
      </LI>
    </LI>
</P>
<TABLE width="100%">
<TBODY>
<TR>
<TD align=left width=778><FONT size=1>GM bulletins are intended for use by
professional technicians, NOT a "do-it-yourselfer". They are written
to inform these technicians of conditions that may occur on some vehicles,
or to provide information that could assist in the proper service of a
vehicle. Properly trained technicians have the equipment, tools,
safety instructions, and know-how to do a job properly and safely.
If a condition is described, DO NOT assume that the bulletin applies to
your vehicle, or that your vehicle will have that condition. See
your GM dealer for information on whether your vehicle may benefit from
the information.
</FONT></TD>
<TD align=middle width=42></TD>
<TD align=middle width=167><FONT size=2>WE SUPPORT VOLUNTARY TECHNICIAN
CERTIFICATION
</FONT></TD></TR></TBODY></TABLE>
<P align=center>© Copyright General Motors Corporation. All Rights
Reserved.
</P>
<FORM name=bottomNavForm>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM></BODY></HTML>
