10-15-2003, 11:17 PM
When should I rotate my tires. I have 12,000 miles. Let me know thanks
10-16-2003, 02:26 AM
I think it should be every 5000 miles but I could be wrong. I have 12K on mine, I think its about time for me too!  BIG-C
White 03-H2-LUX
 </a>
10-16-2003, 04:27 AM
Every 6,000 miles
certified H2 tech.
certified H2 tech. troll
10-16-2003, 12:50 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by PhilD:
According to the H2 Owners Manual the tires should be rotated every 7500 miles. I personally like to rotate the tires every 5000, and usually at 3000 for the first rotation.
Crash, as a Certified H2 tech are you saying that the official line is every 6000?<HR></BLOCKQUOTE>
Phil D thought you fell off the edge off the earth. Thanks Guys Going to do it this weekend. Very over do.
10-16-2003, 03:00 PM
98 ZR-2 Blazer
Ex H2&3 owner
10-17-2003, 01:25 AM
not rotating tires with an aggressive tread about every 5000 miles can cause excessive tire roar and tire damage. happened to a jeep sarhara that i used to have. had to buy all new tires... ther were ruined with only like 15000 miles on them. una
10-17-2003, 09:03 PM
Every other oil change should be just right.
10-17-2003, 09:23 PM
Do you rotate the tires along with the SPARE??????
"A Picture Is Worth A Thousand Words."
10-17-2003, 10:14 PM
I simply choose to have the tires rotated every time I get the oil changed. It just easier for me to keep up with it and I change the oil every 5-7K miles.
I have rotated the spare in the past but haven't on the H2. The logic in the past was that I was going to go with a different tire than I had so just rotating the spare in made sense. If you have the spare tire carrier, a worn tire just doesn't look as good though.
10-18-2003, 12:17 AM
i rotate with oil changes.... it cost 5 extra bucks... I do not rotate the spare into the mix. reason being, is that when it is time to purchase new tires... I only buy three, put the spare on and take the best other one and use that as the spare...why not...it's a spare... did you ever try to lift those tires... those guys who do it for 5 bucks earn every penny. una
