Old 12-21-2005, 12:41 AM
Humm3r Humm3r is offline
Humm3r is off the scale
I've seen quite a few of you on here with 35's. From what I'm gathering, 315/75/r16's ATs do NOT rub at full lock, but I also read that 35x12.5r18s MTs DO rub. After checking out tire dimensions (315/75/R16 MT vs. AT), it seems 35" MT's are about a 1/2" taller and wider than most AT's. I'm guessing we're limited to 35" All Terrains without modification. Correct me if I'm wrong.
Questions:
1. For those with 35's, what brands are fitting without rubbing? bbyhummer mentioned Mickey Thompsons and Pro Comp Xterrains, but I couldn't find true tire dimensions on these.
Nitto Terra Grappler AT's maybe?
2. The stock 33's kick up dirt all over the rear fender and side. Are the 315/75's 'much' worse? I'm more concerned with regular driving...off road, its something you have to expect.
3. Stock chrome rims are the same dimension, but the dealer swears they can't hold the same tire as adv. pkg wheel. Why, I don't know. Will 35's fit stock chrome wheel? 8" seems to be the minimum wheel width required for 35's, but I'm seeing 37s on stock rims It's confusing.
4. Power - Is there a noticeable difference in power? Sticking to a lighter stock rim, I'd imagine it wouldn't be too noticeable.
5. Torsion bars - How many turns, if any, do you recommend?
Kacyk answered a lot of these questions in a past thread, but he had MT's and a heavier 18" rim. I wanted to gather info on 35's on stock rim.
