Old 09-06-2004, 02:55 AM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
Has anyone else had the problem of the passenger rear tire rubbing a hole into the outer edge of the fender well.
I am running 37" TSL SSR's. I know they rub a little up front on the inside of the frame, but so does the factory tires, so that shouldn't be an issue.
But the other day, I was washing the vehicle, and notice a long rub mark in front of the tire that went all the way thru the plastic fender well.
It looks as if when I am at extreme flex, the rear tire may rub at that point(Maybe when the tire was spinning it made that hole?).
Should there be that much flex?
Has anyone else seen this problem?
Thanks for y'alls help!
Ric-H2
www.meatspin.com
