Old 01-09-2005, 01:32 AM
Ain Ain is offline
Ain is off the scale
Looking to see if anyone has some suggestions while I'm stuck in the snow up in Tahoe, 60 miles from a Hummer dealer who won't be open until Monday...
Tried pulling out in the snow this morning with the H2 and the was basically getting no traction. Finally got the thing moving with a push and found that trying to switch from 4HI/lock to 4HI/unlock results in a lot of mechanical noise and then loses all power.
Shifting back to 4HI/lock stops all the grinding noise, but it appears that power is only going to the rear tires. You can see the front wheel shafts rotating, but the hubs don't appear to be locking. Shifting to 4LO seems to have the same result.
Anyone have a suggestion for trying to get the hubs to lock in the front? I've abandoned the H2 for the night, but would like to try to get it moving in the morning and it won't make it too far in the current conditions on 2 wheel drive.
- Ain
