Old 10-23-2005, 11:38 PM
AmericanPatriot AmericanPatriot is offline
AmericanPatriot is off the scale
I was looking to replace the 3157's with some HID. Anyone here done this? Did you just replace the bulb and put a ballast or did you retro fit any lights to fit the DRL light housing?
If you've done so please post some pics.
-Also, I did the DRL jumper in the fuse box so that my DRL's would come on with the Headlights. Will installing HID have any adverse affect? Could doing so blow the fuse?
Old 10-24-2005, 12:08 AM
VTSTOMPER is off the scale
Didn't HIDs4less do that?
I seem to remember many people getting burned by those guys, so I would stay away - if these guys are still around even.
But, I know it has been done.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 10-24-2005, 09:14 PM
Dick Renaud's Avatar
Dick Renaud Dick Renaud is offline
Dick Renaud is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by AmericanPatriot:
PIAA makes a HID that will fit the DRL. I bought a set from Moss Motors for my 06. Don't have the vehicle yet, but will pst pics when I get 8it done.
-Also, I did the DRL jumper in the fuse box so that my DRL's would come on with the Headlights. Will installing HID have any adverse affect? Could doing so blow the fuse? </div></BLOCKQUOTE>
Old 10-24-2005, 09:16 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Dick Renaud:
-Also, I did the DRL jumper in the fuse box so that my DRL's would come on with the Headlights. Will installing HID have any adverse affect? Could doing so blow the fuse? </div></BLOCKQUOTE> </div></BLOCKQUOTE>
Old 10-24-2005, 10:09 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Pittbullcpt replaced his DRL's with HID.
Old 10-25-2005, 09:50 AM
DeBest DeBest is offline
DeBest is off the scale
When you change the DRL's to HID do the fuses change and what effect might that have on the ECM when it detects the additional drain?
Hummafied
06 White H2
00 AMG Mercedes
00 Harley Fatboy
65 Harley Panhead
Old 10-25-2005, 12:18 PM
You use the DRL lead to trigger a relay. The relay hot lead is connected to the positive battery lead and has it own inline fuse. The HIDs have a high amp surge when the first come on and then drop back while operating.
