Old 12-23-2002, 12:27 AM
1 bad h2 1 bad h2 is offline
1 bad h2 is off the scale
ONE OF MY LIGHTS ON THE ROOF BAR GOT VERY LOOSE,IS IT POSSIBLE TO TIGHTEN OR FIX IT,IT GOT LOOSE AT THE BOTTOM WHERE IT SITS ON THE BAR,OR DO I HAVE TO BUY A NEW LIGHT IS IT POSSIBALE TO BUY A LIGHT OR WOULD I HAVE TO REPLACE THE ENTIRE LIGHTBAR?
Old 12-23-2002, 09:24 AM
HummerH2 HummerH2 is offline
HummerH2 is off the scale
How long have you had your H2?
Call your dealer and ask them if your warrenty is still covered.If it is you can go to them and they'll fix it.
Sunset Orange 03' H2 w/Lux,roof lights,wrap around brushguard,Air susp.,On*Star
Old 12-25-2002, 01:28 AM
HummerGirl HummerGirl is offline
Location: In the Deep South, Along the Shore of the Flint River
HummerGirl is off the scale
my roof light was loose as well. the one in the middle on the front of the cab. I tightened mine up. But don't remember what I did to fix it. Water had seeped in under the seal and caused some lift and it loosened up quite a bit.
Maybe this needs to be reported to Hummer.
~amy
~amy
White 2003 H2
Got Soap?
Old 12-25-2002, 05:51 AM
THANKS GUYS,
I WAS ABLE TO FIX MY LIGHT ACTUALLY BY JUST TIGHTNING THE BOLT
THANKS ALOT
REGARDS,
1 BAD HUMMER
