Old 03-14-2006, 10:49 PM
fourfourto's Avatar
My brothers friend Just bought A 96 H1 turbo diesel and the tires leak from beadlocks in 2 to 4 hours any ideas?
Old 03-15-2006, 01:56 AM
CTIS issues?
Old 03-15-2006, 02:24 AM
Beastmaster's Avatar
Beastmaster is off the scale
Liquid soap, water, and a spray bottle. Spray every line and fitting. Whatever blows bubbles is the culprit.
If it's all 4 tires, it might be the solenoid under the hood too.
M101A2 Trailer
Old 03-15-2006, 09:30 AM
fourfourto's Avatar
Posted Mar 14, 11:24 PM
Its acually leaking from the beadlock I beleve its all 4 .Ill have him check the solenoid. If its not the solenoid what could cause it or fix it ? thanks
Old 03-15-2006, 12:47 PM
RonB RonB is offline
RonB is off the scale
what kind of beadlocks are they -- stock two-piece with inner beadlocks or aftermarket? and it only has to be one in the front/one in the back (side to side is plummed (sp?) together).
ron b
Old 03-18-2006, 05:16 PM
fourfourto's Avatar
It seems to be leaking air from the bolts around the rim on all 4 tires in a hour or 2 there flat air up is fine? Not sure if it has factory beadlocks I will look into it
Old 03-21-2006, 09:13 PM
fourfourto's Avatar
My brother brang it to local tire shop they wouldnt touch it.They said go to dealer. It seems all bolts are leaking.
Anyone know what type of bolts/wrench it has and how to get them to stop leaking.The tires look brand new . Thats the way he got it.
Old 03-21-2006, 11:19 PM
Picture? This way, we can tell you what parts you need.
M101A2 Trailer
Old 03-22-2006, 01:39 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
If they are new tires on 2 piece wheels the installer likly did not replace the o-ring that seals the 2 wheel halves. These o-rings need to be replaced every time wheels are taken apart and o-ring grooves need to be cleaned of any corrosion and dirt. during assembly proper torque and torque sequence needs to be followed. Easiest solution take them to your local dealer.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 03-22-2006, 11:34 AM
Joe Joe is offline
Joe is off the scale
yep, sounds like an o-ring issue and if you have it on all 4 sounds like they where never replaced, or pinched when re-assembled. You should be able to get them from a Hummer dealer or try Lynch for a couple bucks each. Just make sure you know if they are red or black in color since there are 2 different types.
2001 H1 Opentop
2003 H2
Homepage:
http://www.hummerh1.net
Old 03-22-2006, 01:41 PM
fourfourto's Avatar
Thanks all for info Ill try to get some pics up.
Old 03-22-2006, 09:29 PM
fourfourto's Avatar
My brother said the bolts look like a stop sign with the bottom cut off.
Anyone know the tool to remove them and where I could get one?
Old 03-23-2006, 12:20 AM
You have a 5 sided nut. Called a Penta-Nut, it's original intentions was to have only trained people undo the rim.
It uses a specialty impact socket to remove. You can then take a 1/2" impact wrench to undo them.
Unfortunately, you're stuck with two options...well, mabye 3.
1) Go to the dealer. If you do, they need to replace the nuts with standard 6 sided nuts.
2) Order a Penta-Nut socket from www.bluehummer.com. Order 6 sided nuts to go with it.
3) Find someone in the area that has one. Order 6 sided nuts as well.
I will say that if you undo this on your own - be careful. I've seen accidents with rims when someone doesn't deflate it properly and completely.
Now - you also have to be sure that you don't have a runflat inside. If you have a runflat inside, you also need a runflat compressor, which is a 4" wide crank operated ratchet strap. That's another dangerous item to work on.
Now you know why the tire shop says that they won't work on them.
M101A2 Trailer
Old 03-23-2006, 09:05 PM
fourfourto's Avatar
My brothers going to dealer to pic up the new o rings and having a shop install that has expertise on the H1.Thanks for all your help
I know its not a H1 but its sill a hummer
