Old 12-15-2005, 09:27 PM
smitham smitham is offline
smitham is off the scale
I have the base radio in my new H3 and realy want to intergrate my I-pod. From what I found it is not possiable with the base unit.
So, I found the 6 disk changer unit on e-bay
http://cgi.ebay.com/ebaymotors/Hummer-H3-indash-6disk-r...temZ8022700816QQrdZ1
Will this unit plug and play (can I just swap out the radios and everything work?) I am not sure if the 6 disk unit has anything wierd with the speakers etc. (I had a corvette and the bose stuff was all wierd somehitng like .5ohm not standard 4ohm.)
Any help would be great.
1997.5 4 door Hardtop for me
2006 H3 Advenure Pkg for her
Old 12-15-2005, 11:19 PM
trading13 trading13 is offline
trading13 is off the scale
That looks the same as mine, its what comes with lux monsoon 6 disk pkg. And no you can't use your ipod with that. Hummer offers one with mp3 but I don't think with both mp3 and 6 disc. You could check out Monsters iCruze to possibly use with your base, I dunno I haven't tried but its something to look into.
Old 12-15-2005, 11:54 PM
I tried ICruze, but the proble with the base unit is that it is not set-up for any external inputs (changer, or XM) From what I have found, this is what these type systems use.
Even if I don't use the I-Pod, will the monsoon head unit work with the base system? This is my main question.
Old 12-16-2005, 12:56 AM
NJHummerGuy's Avatar
NJHummerGuy NJHummerGuy is offline
NJHummerGuy is off the scale
smith...be careful...I was going to do something like this as well as i have the base radio...if you only have base radio and add in the monsoon system, it does not put out as much power as the monsoon goes thru the amp...so you will have to put volume to the top.....
There are a few others posts about this already......I actually ordered one then cancled it...now trying to decide how I want to get sat radio.
Superior Blue, Base, Bush Guard, Mud Flaps, Side Steps, Mud Mats
