Old 12-28-2004, 05:48 PM
LasVegas LasVegas is offline
LasVegas is off the scale
I've read many posts about rattles, especially in the rear. I developed several and pulled off the inside panel. There are several components for wipers, locks, etc. with linkages that ALL were rattle sources. I took a big square of semi-hard upholstery padding and attached it to the entire center section with contact cement. Be sure it's thick enough to cushion but not restrict. Put the panel back on and now quiet as a church mouse. Just thought it might help for those with rattles in the rear.
Jonahs
Jonahs
Jonahs
Old 12-28-2004, 09:53 PM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
Make sure it doesn't restrict motion of any of the components, and won't over heat your wiper motor!
But if it works...DO IT!
Ric-H2
www.meatspin.com
Old 12-29-2004, 05:27 PM
mossinc mossinc is offline
mossinc is off the scale
I had a rattle in the over head console , I fixed this by taking my sunglasses out of it
Two twelve inch subs and a couple thousand watts of power tends to point out most rattles in the truck
I like monkeys !
05 yellow H2
Gobi Rack
Stuff !
