Old 12-31-2004, 03:41 PM
Jimages Jimages is offline
Jimages is off the scale
I want to add lights under the dash which is connected so they turn off/on with the courtesy/dome lights. Does anyone know where to tap into the 12V line for the courtesy lamps? It appears the lamps are controlled through the door modules so the 12V doesn't come through the wiring harness. The dimmer and override switch in the dash seem to control a relay or electronics in another location. Any help would be appreciated.
Old 12-31-2004, 05:05 PM
Hummie2's Avatar
Hummie2 Hummie2 is offline
Here is the schematic for the circuit. Hope it helps. Didn't print very clear, but you can pick up the circuit in the under dash I/P relay box (by your left foot) connector C10 (12way natural color) terminals # C or B. Rt click the picture an "save as" then blow it up, you might see it clearer.
Old 12-31-2004, 05:25 PM
Hummie2's Avatar
I/P relay block
Old 12-31-2004, 05:41 PM
Hummie2's Avatar
Connector C10 pin outs,circuit #690, gray/blk wire color
Old 01-02-2005, 12:21 PM
Hummie2 - Thanks for taking the time and finding this information. It's greatly appreciated and I owe you one!!
Happy New Year
Jim
Old 01-02-2005, 03:43 PM
LasVegas LasVegas is offline
LasVegas is off the scale
Good idea. What lights are you going to use?
Jonahs
Old 01-02-2005, 06:56 PM
I saved all images to My Pictures and they come out a little clearer. Jimages be sure and let us know what kind of under dash lights You use.
Rick
Old 01-04-2005, 06:08 PM
Actually, I haven't gotten to what lights I'm going to use. I do photography and keep some stuff on the passengers side floor when I'm out and about and don't have enough light to find things. I wanted to make sure I could get it wired before I went out and bought the lights.
I also decided to go get the wiring diagrams so I wouldn't have to pester you folks too much. I found the '05 Hummer is on the GM CD's that the Corvette Dr. sells (found on a Google search) http://www.corvettedoctor.com/esi200...infomation.htm
Thanks for your help and I'll keep you updated on what lights I go with.
