Old 09-02-2004, 09:06 PM
HummerKing HummerKing is offline
HummerKing is off the scale
Just talked to my dealer's part department about replacing the stock radio and cd player with a dvd player. They said they wouldn't do it and wouldn't even recommend anyone to do it, because lots of thing going through radio circuits.. like "keyless entry", "seat memories"... if you remove it, you'll remove all of that... But I saw a lot of you doing it, is that true? I'm thinking to remove them, but I don't want to loose other features. How do you guys do it?
Old 09-15-2004, 09:18 AM
drouke drouke is offline
drouke is off the scale
I agree, when I was researching everyone told me that they had to tuck the factory head unit into the dash somewhere. You can add a dvd to your setup and still use the bose head unit mine can be seen here.
http://elcova.com/groupee/forums?a=tpc&s=2826088551&f=6706011751&m=542107297
Old 09-15-2004, 10:41 AM
WhiteH2Kid WhiteH2Kid is offline
WhiteH2Kid is an unknown quantity at this point
There are adapters now i think you need to buy two if you want to change the head unit. When i find the website again with the parts i will post them.
Old 09-16-2004, 01:46 PM
TBarrow TBarrow is offline
TBarrow is off the scale
My factory head unit is in a box in my garage and those functions still work.
Old 09-16-2004, 08:00 PM
intimidator intimidator is offline
intimidator is off the scale
the radio is part of the class2 data uart circuit.the circuit is basically a computer network in the h2. as long as the circuit is not opened all other features will still work.
the modules on the circuit have to communicate with one another or the system will shut down.
these modules are
ipc=instrument panel cluster
radio
hvac= head heating ac control head
pcm=powertrain control module
ddm=driver door module
pdm=passanger door module
dim=dash integration module
bcm=body comtrol module
dsm=drivers seat module
psm=passanger seat module
rim=rear integration module
sdm=airbag sensing and diagnostic module
abstcm=antilock brake traction control module
tccm=transfer case control module
might of left a few out.if you take it to a reputal installer they have the adapters to not disturb the factory setup.
Old 09-17-2004, 12:45 PM
That's awesome to know. Any one in Dallas that would recommend a good shop to do this?
Thanks again.
Old 09-20-2004, 01:31 AM
Hummertech is off the scale
JR'S CUSTOM IN IRVING IS THE ONLY ONE IN THE DALLAS AREA I COULD BEGIN TO TRUST FOR THAT. JUST MAKE SURE THEY GUARANTEE IT, BECAUSE I'VE SEEN THEM MAKE SCREW UP'S. THEY'RE JUST A LITTLE BETTER THAN THE REST.
Old 09-21-2004, 03:48 PM
Hey HummerTech, thank you... is this the one?
http://www.jrscustomauto.com/
