Old 02-01-2006, 03:02 AM
i want some piaa lights that have a black screen and will be able to replace the smaller round headlights in the front, anyone know wat size i need to look for and where i should look? i wanna just swap these for the stock, is it possible?
Old 02-03-2006, 01:10 PM
HUMRCHIC's Avatar
HUMRCHIC HUMRCHIC is offline
HUMRCHIC is off the scale
I am getting mine from eBay. Just do a search for "PIAA" And VIOLA! you've got lights!
2006 H3 in Shadow Green Metallic. Lux. package, Off-Road Pkg, Chrome Pkg, Stainless Hood Vent w/ Handles, Chrome Gas Cap, DVD HDRST, 7speaker Monsoon system. Sunroof,XM. Chrome Nerf bars.
See where other H3 owners are. Click Here
http://www.frappr.com/hummerh3owners
Join our Hummer Community and CHAT live with other H3 owners!!!
http://groups.msn.com/H3Owners
Old 02-03-2006, 01:21 PM
ree's Avatar
ree ree is offline
Check out piaa.com for dimensions on the lights.
Then look for the existing threads by using 'PIAA' and 'DRL' in your Find. (I assume you mean DRLs by "smaller round headlights").
'03 pewter base H2
Old 02-03-2006, 02:55 PM
SoonerBoarder's Avatar
SoonerBoarder SoonerBoarder is offline
SoonerBoarder is off the scale
Piaa 5161 lights fit.
Old 02-03-2006, 09:20 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by SoonerBoarder:
</div></BLOCKQUOTE>
Did you already mount these in that spot? If so, how tough was it. SMA has the kit with a new bumper insert, but it costs some bucks.
twenty2's Avatar
twenty2 twenty2 is offline
piaa 540 works as well...
Old 02-04-2006, 12:57 PM
Basically, you flip the brackets on the light to where they're upside down and where the bolt sticks straight out the back. Then, you drill out the hole in the bumper (plastic, very easy) and bolt the light on. It's pretty easy.
Mine face down a little more than I'd like, so I may "modify" the bracket a little to where it will be more perpendicular. It's a few degrees off right now.
The light itself fits just fine.
Old 02-04-2006, 01:17 PM
FiremanJay's Avatar
FiremanJay FiremanJay is offline
FiremanJay is an unknown quantity at this point
when you wired those up did you connect them into the stock drl wiring harness or did you run a switch?
im thinking i could get the plugs from gm and wire them direct to the drls but dont know if the gauge of the wire is the same or close to it
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
Old 02-04-2006, 01:19 PM
I ran all new wiring and don't use them as DRLs. It could be done pretty easily, though.
