Old 02-07-2006, 09:41 PM
About a month ago, I received a set of Fabtech heavy duty tie rod ends. I had purchased them from Trail Duty (Phil).
After installation when I was pumping grease into the fitting, I noticed a small cut in the boot.
I made a call to Trail Duty and they contacted Fabtech and had 2 replacement boots sent. Though I butchered the first one putting it on, I got the second one on (barely) (apparently, I should have taken the tie rod end off and pressed the boot on... (I didn't))
Anyway, I received an email from Phil today just checking to make sure everything was satisfactory.
I just wanted to say (as many of you already know) If you have to deal with Trail Duty, rest assured that the service is as good as the product.
Mark
Just for record, I've had the EXACT same result from our founder, Jason from The H2 Source.
