Old 07-07-2005, 01:00 PM
Klaus's Avatar
Klaus Klaus is offline
This information applies to 2003-05 Chevrolet and GMC C/K trucks and utilities and Hummer H2.
The memory seat may recall to a more-forward position than previously set. This concern may be difficult to duplicate, and the position may change gradually over time.
Do not replace the memory seat module. Engineering has found the cause to be a coding deficiency in the software of the memory seat module. New memory seat module software was released in TIS version 4.5, dated April 18, 2005.
Klaus's Avatar
Old 07-07-2005, 09:14 PM
dochummer's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">TIS version 4.5 </div></BLOCKQUOTE>
woo hoo!!! So, it's completely fixed? If I understand correctly, just a software upgrade...?
Thanks for the info Klaus
'03 H2
Old 07-08-2005, 12:12 AM
ARH1956 ARH1956 is offline
ARH1956 is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by dochummer:
Thanks for the info Klaus </div></BLOCKQUOTE>What would really be cool is if Software Revision could simply be sent out over OnStar & "Bingo" update complete. Then the next time you get in the car you get a call advising that an upgrade has been successfully installed. Now, that would be cool.
Old 07-08-2005, 02:27 AM
Klaus's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ARH1956:
What would really be cool is if Software Revision could simply be sent out over OnStar & "Bingo" update complete. Then the next time you get in the car you get a call advising that an upgrade has been successfully installed. Now, that would be cool. </div></BLOCKQUOTE>
I doubt that will ever happen. OnStar interferes with firmware upgrades. Aftermarket programmers require you to disable OnStar before programming the computer. Onstar can interrupt the data going across the class 2 databus.
Old 07-08-2005, 02:38 AM
dochummer's Avatar
Klaus, how would my local GM dealer find this info? Is it just an easy look-up and he's got it? Or is there any other info I can give to help him out?
'03 H2
Old 07-08-2005, 03:36 AM
Klaus's Avatar
I'm sure they've seen it, but you can print it out yourself. Here's the link:
http://www.gmtechlink.com/images/iss..._mo/TLcme.html
Old 07-10-2005, 05:57 PM
H2 SVO H2 SVO is offline
H2 SVO is off the scale
So if this is fixed, does that mean that our key fobs will finally have some use to being called #1 and #2? I thought the whole point in that was to remember driver settings??
Old 07-11-2005, 11:32 AM
Hummertech is off the scale
If you have an 05, just doing this reprogram will not remember 1 and 2. You can have a different module reprogrammed to change that.
Old 07-12-2005, 02:53 AM
I do have an 05..
Could you be realy specifc about what I need to get done so I can relay it to the dealer folks {they are slower than slow when it comes to getting them to understand something}
Old 07-12-2005, 03:28 AM
dochummer's Avatar
I just brought my H2 in for a seatbelt fix, and notified them of the seat memory fix on the gm tech website. They said that they would check into it and let me know.... I should get it back tomorrow, so I'll let you know...
'03 H2
Old 07-12-2005, 10:07 AM
It's been a month or two since I did one last. I believe it's the BCM that you have to reprogram. The dealer will have to call GM and get what is called a VCI#, which is basically a vehicle specific reprogram number. They will have to tell GM what they are trying to do, and GM will give them that #. This is a little bit of a pain in the rear, so if your dealership doesn't want to help you, expect them to give you a line saying it can't be done. But it can be. WE've done it to 6 or 7 trucks.
Old 07-12-2005, 07:05 PM
dochummer's Avatar
Just got the rig back from the local dealer and they reprogrammed the seat module. We'll see what happens...
'03 H2
Old 07-20-2005, 02:45 PM
dochummer's Avatar
Just a quick update, it's been a week now with no problem with the seat memory recall. It seems to be working perfectly!
'03 H2
Old 07-20-2005, 02:52 PM
vip808 vip808 is offline
vip808 is off the scale
If the seat memory recall is in the BCM, why does removing the stock stereo disable this feature?
Old 07-22-2005, 10:30 AM
Because the radio works with the whole system. The radio sets the presets to driver 1 or driver 2's settings. If you take any important piece out of the puzzle, it won't work right.
