Old 04-20-2006, 12:27 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
Wanted to be cool like everyone else, so I put in a rear camera.
LCD Cost - $99 at Frys (Diamond Audio)
Camera Cost - $50 at Frys (XO Visions HTC-200) And could have got it even cheaper off ebay
http://community.webshots.com/photo/...85270165dKlnja
http://community.webshots.com/photo/...85270165yeJTvW
http://community.webshots.com/photo/...85270165Dtxiox
http://community.webshots.com/photo/...85270165XEiTrn
I've already ordered a 2 pole, 6 way switch from allied electronics, I'll be installing a few other cameras and then using the switch to...well...switch between the cameras.
Camera locations:
Roof Rack (to check for clearances and make sure everything is staying locked down)
Front Axle
Rear Axle
Front lower grill (just because I think that would be cool)
Any other ideas? At $50 a piece, the cameras are cheap and it's just a matter of wiring (easy)
This particular LCD also has a video out, and I'm going to order a Archos or other PVP with video in - eventually I'll be able to capture video of the cameras and post somewhere. Now, if I could just get the time to go to Moab with the rest of you!
Old 04-20-2006, 02:45 AM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
Nice job. Another inexepensive alternative.
WWW.BCBI.COM
Old 04-20-2006, 03:35 AM
HummerHawaii's Avatar
HummerHawaii HummerHawaii is offline
HummerHawaii is off the scale
i had another post regarding rearview cameras similar to what you did..
http://elcova.com/groupee/forums/a/t...1/m/8371040871
but my question is where did you run your wire?? can u take some pics with it??
and did you just drilla hole in your dash???
Sup. Blu H3/DvD Navigation+DvD Changer/Rear CCD IR Camera/ SplashGuard, LocKing Billet gas cap, 4" Step Nerf Bars/Underbody lightning, and adding..
Old 04-20-2006, 04:15 AM
Nice affordable setup. No blind spots anywhere on your rig.
S.
Old 04-20-2006, 09:24 AM
DarthKarl's Avatar
DarthKarl is off the scale
Very nice setup
Looks good
Old 04-20-2006, 11:51 AM
So how is the viewing angle of the camera from the position? Does it cover enough area that you can see what you might hit on either corner? Thinking about picking up a couple of those.
