Old 03-04-2006, 02:06 PM
yat74's Avatar
yat74 yat74 is offline
yat74 is an unknown quantity at this point
Are the rocker bars as easy to remove and replace as the step bars, I wonder if switching when going offroad would be a pain? 4 bolts and you're good?
The Goat
Old 03-04-2006, 02:11 PM
There are more than 4 bolts, but they basically go on the same sort of way.
Old 03-04-2006, 03:02 PM
They bolt up with 8 bolts each side, and they are a bish to tighten. You need air tools,.
Old 03-04-2006, 03:18 PM
I don't want to hear that. I may be doing mine in the parking lot of the hotel when we go up to Tellico next weekend. Waiting to hear today on shipping but probably getting them and having them shipped to the hotel since they probably wouldn't get here in time. After I get back I plan on doing to custom brackets so both the step and rock rails can be on at the same time.
Old 03-04-2006, 04:34 PM
Not sure why everyone says you need air tools to install the rocker protectors. I have helped install two sets, and no air tools were needed, and the official time study performed by GM for warranty on these steps had to be performed using hand tools (GM requirement).
Old 03-04-2006, 04:52 PM
It has to do with my lack of upper body strength
No really, it had to do with getting everything lined up, and with all the cables and lines on the drivers side. Also, I did do it by myself. Not easy, but easier with air tools.
Old 03-04-2006, 05:17 PM
westhillsat's Avatar
I will put mine on before heading to Moab. I'll request the wife's and son's presence while installing
Old 03-04-2006, 07:23 PM
Edspad Edspad is offline
Edspad is off the scale
Im on my way to Install mine right now, i will let you know.
It is a good thing for an uneducated man to read books of quotations. - Sir Winston Churchill
Old 03-04-2006, 10:48 PM
DarthKarl's Avatar
DarthKarl is off the scale
Seems like the best solution would be to keep the rockers on all the time and go with the removable U-steps. I think that would be a whole lot easier.
Old 03-04-2006, 11:52 PM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
X2
WWW.BCBI.COM
Old 03-05-2006, 12:46 AM
Originally posted by hmrlvr:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Seems like the best solution would be to keep the rockers on all the time and go with the removable U-steps. I think that would be a whole lot easier.
X2 </div></BLOCKQUOTE>
X3 on that, Plus i would follow HummBebe advice and break out the air compressor (left mine at home) would make those hard to reach bolts go faster
Old 03-05-2006, 05:33 PM
Ipedog's Avatar
Ipedog Ipedog is offline
x4 - I've got the U-Steps and they are really easy to take on and off. About 20 minutes total for all four using hand tools. I'm sure it's faster w/air.
Rob (Ipedog - Say "Ip-E-Dog")
Black Sheep HUMMER Squadron
Old 03-05-2006, 06:07 PM
I can understand why GM wants it done by hand too. If you don't thread it first, and make sure it going in correctly, it has the potential of being crossthreaded and damaged. The area on the drivers side is so tight, it makes it very difficult.
TIP:
when using airtools, be sure to thread first, and do not over tighten. A light hand is best in this situation.
