07-07-2004, 06:40 PM
I need to re-paint my H2 dash in original colours. I heard its powder coat, but when I looked into it, Powder coat is a high temperature process only. Does anyone know a paint shop that can tell me how the "gritty" surface is done. Matching the colour is easy, but not the finish.
07-08-2004, 12:09 AM
As you found out, you cannot powdercoat plastic.
Any good body shop can smooth the plastic dask parts and then paint and clear coat.
Check around--if you take the parts off yourself and deliver them, you will save a fair amount.
07-09-2004, 03:24 AM
Humby-
There are also several places on the internet that do this. I think the process is called photogenesis/hydrographics. Here is a website that does it for you but you have to send them the pieces you want done.
http://www.exoticwooddash.com/coating.htm
However, I remember seeing a website that would do it which didn't require you to send your pieces in; they had the pieces in stock and you just sent them your pieces after they sent you the new ones.
I hope this helps...
-HUMMERDOGG
07-09-2004, 08:02 PM
Thanks folks, but when i say "original" colours, I mean the real gritty, silver paint that comes with the original Hummer.
Thanks for the replies so far.
