Old 11-09-2005, 02:03 AM
VTSTOMPER is off the scale
This seems kinda kewl.
First let me tell you I only have been running 87 octane with each and every fill up, and temps were NOT constant…nor were AC usage or drag with windows, towing…well you get the idea.
I only have a few choices when I fill up, but here is what I have found so far:
Mobil
Texaco
Shell
Citco
Sunoco
Gulf
*GOGO GAS - surplus fuel *crappy I am told*
When I fill up, I am usually near dry…so as little mixing is going on as possible, but I have found that when I fill up I get better MPG when I run Mobil fuel in the truck. So I have been running Mobil all the time. I am probably the only weirdo that has been doing this…but has anyone else tried it?
I know this is not a PERFECT test...but I would like to try it in a controlled environment.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
