Old 11-03-2003, 12:02 AM
Frank Hewitt Frank Hewitt is offline
Frank Hewitt is off the scale
I have had the bad experience of using armorall wipes on my H2 interior. It caused more squeaking of the interior (ie the doors) than I ever imagined. I fixed the trouble with spray lube which returned my interior to an entirely noiseless situation. There is enough outside noise (on the highway) in the H2-- having interior noise(including even the sunroof button). Eliminating extra noises has been heavenly. I'll never use armorall again on my H2, and would encourage the same. If you've ever used "it" you know what I mean.
gasman
gasman
gasman
gasman
Old 11-03-2003, 12:15 AM
uniblack uniblack is offline
uniblack is off the scale
I second this thought.
Do not ever use armorall on the interior of a vehicle. Use warm water on a damp cloth to clean the interior. The gloss levels on the interior are too high as it is. Armorall only promotes gloss. Interiors look much better when the plastic components are not a "mirror" finish. Low gloss is the way to go.
[[uniblack]]
[[uniblack]]
Old 11-03-2003, 01:17 AM
H2Doc's Avatar
H2Doc H2Doc is offline
H2Doc is off the scale
On the inside, I like those electrostatic cling dry wipes my wife raves about to get dust in hard to reach places. Armorall works great on all that exterior plastic.
Brian
Old 11-03-2003, 05:31 AM
cmb31078 cmb31078 is offline
cmb31078 is off the scale
I have heard from several people to use Pledge. It does not harm the interior like amorall does.
Craig
Craig
04 Pewter H2- Lux,nav, air suspension
Old 11-03-2003, 10:51 AM
Dan Dan is offline
Armorall attracts dirt, I quit using it years ago.
I think H2Doc is talking about the Swiffer
- Dan
SUT on order 12/02. 11 months down, 7 to go!
Old 11-03-2003, 07:25 PM
austoak austoak is offline
austoak is off the scale
Years ago I used to use armorall on my tires as well as the dash. After awhile I could see small spider cracks throughout the entire tire as well as the dash. Somebody had once told me not to use it because it causes cracks. They were right!!!
Old 11-03-2003, 08:19 PM
SUTJim SUTJim is offline
SUTJim is off the scale
Throughout my life I have heard many negative things about armorall. It contains alcohol that evaporates and makes things worse. How does this product survive all the negative word of mouth?
Current Chevy Avalanche owner,
future H2 SUT owner
Current Chevy Avalanche owner(Sold it),
future H2 SUT owner
Old 11-03-2003, 11:01 PM
right--- armorall creates the tire equivalent of a crack addict; it suffers badly if you don't use it religiously.
Pledge, huh???? never heard that. I'll have to check out the nonstatic whipes.
I also wonder if you guys and gals have a proven cleaner for the plexiglass (gauge faces and speedometer face covering) that will take off the dust/dirt without scratching?
Thanks for your replies.
I've also found that armorall does well for the black plastic outside(I don't have the chrome package so there's lots of black plastic) other than the tires, which I learned years ago that armorall will result in cracks.
gasman
gasman
Old 11-04-2003, 05:34 AM
The pledge recomendation comes from a custom car interior specialist in Nashville. They get all of the interior leather work from the benz and bmw dealer in town. They both recommend them. So I have used it and no problems here.
Craig
Old 11-04-2003, 09:58 AM
Dan Dan is offline
I use this stuff made by 3M. I forgot the name but its some sort of glaze. It dries to a smooth, non sticky, not greasy finish. I'll look at the bottle later & post the name.
The only problem is it smells like ass in the car for a day.
- Dan
