Old 08-28-2004, 09:40 AM
Humby Humby is offline
Humby is off the scale
Anyone know how to get hold of the software that goes in the standard diagnostic scanner for GM / Toyoa, so i can clear my own faults with a laptop?
Needed because I have "Service airbag" fault code to clear, and I do not have access to the dealership.
Regards,
Mike.
Regards,
Mike.
Old 08-28-2004, 10:02 AM
Hummie2's Avatar
Hummie2 Hummie2 is offline
Most of the programmers like the Preadator (about $300+) have a scan feature also and allow you to clear fault codes.
Old 08-30-2004, 07:43 AM
Thanks,
Have you tried the predator and can you reccomend it?
I have seen it on the net, but the advert was unclear about its exact capabilities on fault code clearance.
Many thans
Mike
Regards,
Mike.
Old 08-30-2004, 05:41 PM
Hummie2's Avatar
I have a Predator and have used it to clear fault codes that set when the engine electrical got wet (be careful washing the engine). I can't really say what it's limitations are though, but I wouldn't expect it to do what a real scan tool would.
