Old 06-18-2005, 03:35 PM
GBergie GBergie is offline
GBergie is off the scale
Just bought my H1 (two days ago) and found a broken starter bolt. Is this common with H1's???
Old 06-18-2005, 07:57 PM
Beastmaster's Avatar
Beastmaster is off the scale
Yes. It's a common item to check that the bolts are tight every 'C' Service.
If your truck is still under warranty, have the dealer fix it. If it's not, it's an easy fix to replace the bolt if it hasn't sheared off in such a way that the threads are destroyed.
It would also help if you provided a tad bit more info on the truck. Year, engine (NA/TD/Gas), etc.
-Steve
M101A2 Trailer
Old 06-18-2005, 10:31 PM
My H1 is a 98 with a 6.5 turbo type
Old 06-19-2005, 02:14 AM
Buy this:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewIte...rd=1&ssPageName=WDVW
It's the right starter bolts. 9 bucks can't beat it.
M101A2 Trailer
Old 08-09-2005, 11:11 PM
Shawn from Angry Iron Shawn from Angry Iron is offline
Shawn from Angry Iron is off the scale
If you have seen the Moab movie, then you would have seen them trying to replace a loose bolt in the starter on my truck. Well it wasn't lose it was snapped. After the truck made it back here to GA I climbed underneath to evaluated the damage. I was imbarassed that I had not cought the previous shotty maintenance of the starter instalation. The one remainig bolt had 3 over size nuts used as spacers.
Next after removing the starter I proceeded to easy out the snapped bolt When I did I found I had two bolt ends on my easy out. same thing on the hole that the other POS bolt was in. I guess some previous owner, could have been a Marine. Just drilled into the snapped starter bolts and tapped threads in the smaller holes.
So after two new Chevy starter bolts from a local parts store it is as good as new.
To add yes this is very common especially if someone has not used the third bolt/nut at the motor mount.
Shawn
85 HMMWV
Angry Iron www.angryiron.com
Taking the High Ground
